i think running a T4k is probably the biggest waste of money ever
to each there own, if i had the money for a t4k i would get it and run it to two subs...dont have the money, and nor do i have the space if i have a back seat...
if you do run a t4k on the two you will have one hella of a beat
you will still have a bad ass thump with a t3k tho
My F-150 Build
GET ON THE BANDWAGON
what if they tried messing with the amps when the subs werent louder :ehh: hahah jk :pardon:
maybe a d1 and run it at 2ohms, but the 4ohms is worse then what you said not to do with the t3k and 2 of them
well obviosly dont wire them both to 4 ohm final that would be stupid...im saying if he gets the t4k and 1 btl, that way he can still hammer on it, and not worry..then when he gets the other btl...change the ohm load and be set
My F-150 Build
i typed that out wrong i edited it.
and i have a t4k, at 4ohms theres alot better options, unless your looking at going sq 4ohm wouldnt be a load id run it at and if i did i sure wouldnt use the BTL for that SQ setup
also if he got a d2 btl his option is running it at 4ohms like 1200rms or 1 ohm 4k plus
he can get the dual 1 ohm ones, run it at 2 ohm, all gains down, get the other btl and run both of them at 4k plus 1 ohm load
thats what i would do, i think it would sound best and be most beneficial for him....if he wants mind numbing bass that is
My F-150 Build
but as stated in the original post, he cannot afford the amp
ive seen bxi1600s on btl and they did fine, hed have more then enough "bump off the 3k.
