MonkeyBoy Posted February 1, 2013 Report Posted February 1, 2013 This has happened at least twice now where I'll post a topic asking a question and it'll soon disappear as if I never posted it. ?? I had asked if I could use different brand/sizes of midbass drivers with existing component sets or not due to failure of original midbass drivers in the set. I had worded it differently with more description and details but I'm hesitant to do that again due to worrying that my thread will magically vanish again. 1996 Trooper LS 4X4 3.2L SOHC - Pioneer Head Unit, Big 3 Upgrade, Knuconceptz 1/0 Wiring, Polk 6X9's in the rear doors, Polk 6.5" Front Components, Coustic 4ch 1200W Amp, Rockford Fosgate R1000-R1 Sub Amp, Diamond Audio D912D4 12" Sub, Sub Zero 12" Vented Box, Airtec Snorkel - 6000K BiXenon HIDs - 16x7.5" Snowflakes - ARB Front Winch Bumper - Vortex 12000lb Winch - Superwinch Manual Hubs - 3" lift OME 919's + Coil Spacer -OME Nitrochargers - HD Lower Links - Front Control Arm Low Profile Droop Snubbers - Poly SwayBar Bushings - Ball Joint Flip + 1/4" Spacers.
Kyblack76 Posted February 1, 2013 Report Posted February 1, 2013 So, this post that is off topic, and fairly random, belongs in the general audio section?? This one will probably disappear. IN BEFORE GONE! SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
MonkeyBoy Posted February 1, 2013 Author Report Posted February 1, 2013 I put it in here becuase this is where my General Audio questions have disappeared from. I did pose an audio question as well :-) 1996 Trooper LS 4X4 3.2L SOHC - Pioneer Head Unit, Big 3 Upgrade, Knuconceptz 1/0 Wiring, Polk 6X9's in the rear doors, Polk 6.5" Front Components, Coustic 4ch 1200W Amp, Rockford Fosgate R1000-R1 Sub Amp, Diamond Audio D912D4 12" Sub, Sub Zero 12" Vented Box, Airtec Snorkel - 6000K BiXenon HIDs - 16x7.5" Snowflakes - ARB Front Winch Bumper - Vortex 12000lb Winch - Superwinch Manual Hubs - 3" lift OME 919's + Coil Spacer -OME Nitrochargers - HD Lower Links - Front Control Arm Low Profile Droop Snubbers - Poly SwayBar Bushings - Ball Joint Flip + 1/4" Spacers.
n8ball2013 Posted February 1, 2013 Report Posted February 1, 2013 start putting it in the right section. general audio isnt the dumping ground. you're asking about a speaker put it in the mids and speakers section. amps ditto subwoofers again. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
n8ball2013 Posted February 1, 2013 Report Posted February 1, 2013 except youre not asking a question that fitst he category. you're asking abotu a specific thing. it gets real old to come on the forum and see stuff in general audio that has a section dedicated to it. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
MonkeyBoy Posted February 1, 2013 Author Report Posted February 1, 2013 Interesting... I must not have looked hard enough, I thought I had! If that's the case I apologize! I had thought if I'd posted incorrectly I'd be notified that the thread was deleted or moved as is standard practice on other boards, I assumed it was the same here. 1996 Trooper LS 4X4 3.2L SOHC - Pioneer Head Unit, Big 3 Upgrade, Knuconceptz 1/0 Wiring, Polk 6X9's in the rear doors, Polk 6.5" Front Components, Coustic 4ch 1200W Amp, Rockford Fosgate R1000-R1 Sub Amp, Diamond Audio D912D4 12" Sub, Sub Zero 12" Vented Box, Airtec Snorkel - 6000K BiXenon HIDs - 16x7.5" Snowflakes - ARB Front Winch Bumper - Vortex 12000lb Winch - Superwinch Manual Hubs - 3" lift OME 919's + Coil Spacer -OME Nitrochargers - HD Lower Links - Front Control Arm Low Profile Droop Snubbers - Poly SwayBar Bushings - Ball Joint Flip + 1/4" Spacers.
Kyblack76 Posted February 1, 2013 Report Posted February 1, 2013 There is another issue I won't get into about proper thread placement. Just try and place your posts in proper locations. It helps in ways you don't even know. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
MonkeyBoy Posted February 1, 2013 Author Report Posted February 1, 2013 Fixed, finally found the proper place. In other forums as soon as you get to the sponers section as you're scrolling down you've reached the end. There's more here, my mistake. 1996 Trooper LS 4X4 3.2L SOHC - Pioneer Head Unit, Big 3 Upgrade, Knuconceptz 1/0 Wiring, Polk 6X9's in the rear doors, Polk 6.5" Front Components, Coustic 4ch 1200W Amp, Rockford Fosgate R1000-R1 Sub Amp, Diamond Audio D912D4 12" Sub, Sub Zero 12" Vented Box, Airtec Snorkel - 6000K BiXenon HIDs - 16x7.5" Snowflakes - ARB Front Winch Bumper - Vortex 12000lb Winch - Superwinch Manual Hubs - 3" lift OME 919's + Coil Spacer -OME Nitrochargers - HD Lower Links - Front Control Arm Low Profile Droop Snubbers - Poly SwayBar Bushings - Ball Joint Flip + 1/4" Spacers.
Kyblack76 Posted February 1, 2013 Report Posted February 1, 2013 Got some shots of your trooper? Looks like your set up for some trail riding/rock crawling ? Im into that as well.. Cheers, and welcome.... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
