They were built by psi back in june of last year and have almost every option they offer
d1 4 layer flatwind coil
triple sewn leadwires
white cone
8 ga direct leads
dished carbon fiber dustcap
I paid $450 for the recones alone. I also added around 5' of AT ofc to the direct leads. The baskets mounting have been drilled out to be able to take a 1/4" machine screw
They did a 151.1 at 1 ohm on an opti6k with weak electrical and a 149.0 at 1 ohm on a bc3500.
The reason Im selling them cheap is because they make a static sound on low volumes but it goes away once they get turned up (coil rub, loose dustcap?) If I tap on the cone they make the same sound
They have been doing this for a few months now but Im not sure what the issue with them is, They did the 149.0 about 2 weeks before I took them out so they still slam.
Asking $450 shipped for both or trade
mounting hole, all are the same as this one
Used to have a loud truck
Ok. Ill let you know.
yes, 450 for the pair. I'd rather not separate right now
Someone buy these before I recone them into 10"s and put them in my wifes car.
