well say goodbuy to your back seat then... or you going to try and cram an 18 in the trunk?
previously known as wenn_du_weinst aka fucking internet coward supreme.  I talk shit on other forums like a little bitch and hope i don't get caught out on the street.
I was thinking about it doing sub up port back but after looking on youtube a single 15 sub back port back beats like a mofo. I'm just trying to get the most out of a setup whether it's split wattage and more surface area or more wattage to a single sub. Guess I'll have to wait for the exact car it's going in. Sh@t man I wanna do a wall with two 18"s but I like the element of suprise when you pull up and beat the hell out of the block from the trunk.
I have the ZX1500.1 on a 15" L7 and 2 ZX200.2 push the mids/highs. The ZX1500 is a great every day amp. I've add a 2nd battery and a cap and my volts never drops below 11.9 at full volume. If you can i would advices you to get a 1500 on two 12" L7. You will be very happy with the setup. When i get some more money i'm going to add another 1500 and change my sub to a solo-x D2 AND HAVE 1 ZX1500 ON EACH VOICE COIL AND ADD A 250 AMP ALT
1993 Mazda Mx-3
Subs: 2 18" DC Audio Lvl 4 D.7
Highs amp: Sundown SAX-100.4
Sub amp: Sundown SAZ-3000D
Electrical:Kinetik 1200 under hood, 2-Kinetik 2400 rear
All 1/0 KnuKonceptz Wire Power/Ground, Big 3, 8Ga Speaker Wire, KnuKonceptz Karma RCA's
Dampening: 120sqft 80Mil Thick Sound Destroyer Mat
Goal: 150 DB 149.9 Street Bass
I'm really liking the 2500.1 but if I don't get it it'll definately be the 1500.1. I'll prolly do a dual 12 or single 15 setup with the 1500 or a single 12, 15 with the 2500. Those are the setups I'm thinking about. Do the 1500's have 1/0 gauge inputs?
i'm not sure but i think they do. i know the 1000.1 has a 4 ga.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
With running something like the 2500 would I need a battery in the back or would a ho alt and a 1800 or 2000 kinetic under the hood be sufficient, or would a ho alt and kinetic 800 in the trunk be better?
i have a stock atl and battery up front and a kintek 800 and a 6 farad cap in the rear. it seem to do the trick. if you are going to use the 2500 you could add a highout alt to your budget. the 1500 only takes a 4 ga wire. my setup is a single 15 pushed by the 1500 and its way more then a expected. i haven't put it on a meter but my last system was doing 142 and this is way louder so i'm thinking it should do about 145. i don't know what you are really tring to do but the 1500 is more then enouch amp for everyday pounding. the 2500 would be over kill. two 12's on that then i hope use are going to get some solox or something along that line. i don't think the L7 can handle that kind of power. i'm over powering my L7 with the 1500. the dealer told me i shoud have 2 15's on it but i'm hard headed...lol good luck what ever way you go. just remenber when you do your budget you as in all the little stuff you need. i went over budget by 400 buck just termial rings , wires and contactor. that little shit really adds up
1993 Mazda Mx-3
If I do get the 2500 I'll prolly do a single fully loaded btl either 12 or 15, or something along the lines of that thats comparable to the btl. If its the 1500 prolly 2 12's either fi ssd's or 2 level 4 dc's. I can't afford the best but I'm buying a new peice every couple days of decent quality stuff. So far I dropped 250.00 on a bunch of Knukonceptz products, 160.00 on a Alpine 9881(I think thats the right model), another 160.00 tomorrow on a kicker 350.4. After this comes the sub amp and the 6x9's and the last thing will be subs. I'm not getting into electrical yet cause I don't know what kind of car I'll be working with yet.
sounds like you have everything planned out. once you figure out what car you'll be getting then you can decide on two 12s, one 15 or whatever you decide to go with.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
  • Who's Online   0 Members, 0 Anonymous, 684 Guests (See full list)
