Like said, I just installed an alternator, and now its squeaking rather loudly...I've tried loosening and tightening the belt....Ideas. Its a 225 am EA and my vehicle is in my sig... Please help
A vitrolic, megalomaniacal sadistic psychopath.
It squeaks more when I rev...If that helps
...also when I first installed it, and reved everything to test it up, it only squeaked a little on the startup but stopped. When I started to actually drive home, it started squeaking a lot so I immediately went back to the driveway
Edited by littleitaly1990
if u remove/loose the belt and spin the alt fast with ur hand.. does it still make that sound?
other than that, only things that come to mind atm is how tight the belt is... but u alreayd tryd that
  • '02 Jetta
  • (1) Fi Btl 18 Inch Sub
  • Big box FTW!
  • Installed the HU.. finally...
  • Look for a H.O. Alt
    yea... it bangs.. but still need some few things
Have you tried to not tighten your belt super tight. Sometimes they can be to tight. Also your pully might be rubbing the inside of your case. I would have to be where you are to determine that.
  • Who's Online   0 Members, 0 Anonymous, 5077 Guests (See full list)
