Going to be Deadening the whole rear half of car and doors. Also building box for SSA XCON 15" nothing really special. Will more than likely be using MurderMat MDK for trunk/rear deck and BL for the doors. Will get some before and after videos of the flex and rattle. Will get pics of the Car up soon.
Pics of the XCON i picked up locally for $200.
Backseat out and most of trim out, not gonna remove trunk stuff til deadener arrives.
Got wood and supplies to build box
Box Design(keeping it simple for now since this is my first box)[box design credit goes to Joe X(even though he suggested against sub up)]
Enclosure Specifications:
Fb = 32 Hz
Vb = 4 ft^3
External Height = 14 in
External Width = 33 in
External Depth = 27 in
Port Width = 5 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Top & Bottom (3 parts) = 33 x 27
Left & Right Sides =
Side 1 = 25 1/2 x 11 3/4
Side 2 = 26 1/4 x 11 3/4
Front = 27 1/4 x 11 3/4
Back = 33 x 11 3/4
L Port Internal Assembly Parts:
Front to Back = 20 1/2 x 11 3/4
Extension = 3 x 11 3/4
I'm going to be following this, recently bought the wife one of these. Looking forward to updates!
Build log: Click
Feedback: http://www.stevemead...xbccp-feedback/
03 Chevy Blazer
- IPad Air 2
- ALPINE Head Unit
- 4 DC XL 18s
- 2 DC 3.5k
- ALPINE TYPE R 5.25 COMP
- 3 ALPINE TYPE R 6.5 COMPs
- DC 175.4
- DC HO Alt
- D3400
- 4 XP3000s
- KNU 0ga
- 60 SqFt Damp Pro
Lots more...
Little update. Murdermat deadener should be here in the next day or so. Finishing up box build, don't think i did all that bad considering it is my first.
Back, sides and port glued in.
First coat of resin
Second coat of resin and resined bot of top before i glue it on.
how come you're using 4 gauge for the 2200? are you running it at 2 ohms or something?
Kranny, on 05 Feb 2013 - 18:09, said: how come you're using 4 gauge for the 2200? are you running it at 2 ohms or something?
Yeh the sa12 that i am currently using is at 2 ohms.
Update, Murdermat came in. Sub finally in box and in car, not deadened yet. Will post up some videos of flex and what not tomorrow. Will also post pics of Murdermat.
Pics of box in car:
Yay no trunk left...
And actually the way its in there i can't even put my back seat back in... Will have to see if i can turn it while it's in the trunk. Will also post some pics of the box out of the trunk tomorrow as well. Would do it now, but damn this thing is fucking heavy to pick up alone... Plan on glassing the outside this weekend and painting. Anyone have any suggestions as to what to put on the bottom of the box so it will slide easier??
