vw passat Posted February 5, 2013 Author Report Posted February 5, 2013 it have less port are and port area per foot than the last one iv post or it dosent matter?
zxsonnyxz Posted February 5, 2013 Report Posted February 5, 2013 What about this: 15.5x3" port, 30hz tuning. Then whatever lengths you need. You need single layer wood to not lose space, so a couple strengthening rods should be used. I think that would work, can make a SketchUp later. STD Passat Build 151db+STD Omega BuildMitsubishi Colt Build - Alpine|Focal|PeerlessHome Stereo BuildSmall Tang Band build - 4" fullrangeBox for 4 8"My Saab 9000 Build- I'd be very happy if you cared to check out the logs and give feedback!
vw passat Posted February 5, 2013 Author Report Posted February 5, 2013 so i use the last specs that iv post zxsonnyxz?
zxsonnyxz Posted February 5, 2013 Report Posted February 5, 2013 Kind of a mix between them all, I think this could work: Just about enough port, 30hz tuning, 3.3cu.ft after displacement. I even think the single layer of wood is good enough on this, but a rod between top/bottom won't hurt. (Or two, one on each side of magnet) Done with 3/4in wood. Remember to round over the edges in the port, or else you will have port noise. And if there's something terribly wrong here, let me know. STD Passat Build 151db+STD Omega BuildMitsubishi Colt Build - Alpine|Focal|PeerlessHome Stereo BuildSmall Tang Band build - 4" fullrangeBox for 4 8"My Saab 9000 Build- I'd be very happy if you cared to check out the logs and give feedback!
vw passat Posted February 6, 2013 Author Report Posted February 6, 2013 i was thinking that with 31hz i cannot go to 54hz peak because my song for base race is 54hz. iv made this specs with aero port so when i need to go for a comp i only change the port. iv never made a box with aero port so guys i need some help if i have everything good and last one question i make the port external or internal? and if external can i make it facing back? and i need to put the lenght of external port in the torres box? tx guys
vw passat Posted February 6, 2013 Author Report Posted February 6, 2013 IMG]http://i49.tinypic.com/syb2ph.jpg[/img]
Spencer Good Posted February 6, 2013 Report Posted February 6, 2013 You've literally posted 5 threads on the exact same subject.. Come on man. 2012 TORed Challenger 4 Alpine Type-R 10 1 Brutus 2400.1 20' Knu 1/0 OFC 1 XS Power D1200
vw passat Posted February 6, 2013 Author Report Posted February 6, 2013 i dont even know nothing on this things so pls i need help
Spencer Good Posted February 6, 2013 Report Posted February 6, 2013 i dont even know nothing on this things so pls i need help People have pointed you in the right direction and even offered designs multiple times.. 2012 TORed Challenger 4 Alpine Type-R 10 1 Brutus 2400.1 20' Knu 1/0 OFC 1 XS Power D1200
vw passat Posted February 6, 2013 Author Report Posted February 6, 2013 sry. so at least you can tell me if the last specs are good? tx Spencer Good
