riverman86 Posted February 5, 2013 Report Posted February 5, 2013 I have a RF 1500 mono block on 2 solo baric 12" 2 ohm dvc wired series parrallel @ 2ohms. Wanting to know what to set my gain,response,and punch eq at for absolute top out without distortion? Any advice would be greatly appreciated!
Kyblack76 Posted February 5, 2013 Report Posted February 5, 2013 Edit SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
riverman86 Posted February 5, 2013 Author Report Posted February 5, 2013 just seems like some of my lows are clean and some of my highs are right at times and on other songs it just sounds like shit.
appealingrelic Posted February 5, 2013 Report Posted February 5, 2013 its a tool that helps you set gains perfectly brought to you by the man himself, steve meade http://www.wccaraudio.com/smd-distortion-detector-dd-1.html or check this map for someone near your location http://batchgeo.com/map/93b3e7dfd7ea8496a6f1640587e3e4cf
Noel989 Posted February 5, 2013 Report Posted February 5, 2013 Dd-1 or an oscilloscope to set the gains Check the map or ask if theirs anyone ne'er you with either of those tools Eq to 0 or it's lowest point The response I'm guessing that the low pass filter set that around 80-100 hertz And your amp should have a subsonic filter set that around 30 herts Is your amp a bd or bdcp? Or witch series/model is it? Build Log - http://www.stevemead...-cruiser-el-pt/
