Quick Fusing Question
So i have 2 runs of 1/0 to a distro block then straight to a kx2500.1. should i use a 100amp fuse or 200amp fuse on each run. all the power wire is going to the amp and nothing else. I'm assuming the both wires are sharing the same load and I should go with 100amp but I'm just makin sure
that will be fine..i personally use the largest fuse you are suppose to when doing things...which is like 300 or 350amps for 1/0 gauge wire iirc
i likes me some audio stuff...
1/0 gauge wire calls for a 300 amp fuse .......... so does that kick 2500.1
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
  • Who's Online   0 Members, 0 Anonymous, 5077 Guests (See full list)
