mnrookie Posted February 7, 2013 Report Share Posted February 7, 2013 This is my first time making a box, it's for my brother. It is 2 12" Audioque SDC2.5's. Anyone see anything wrong with this design? I figured I would try my first box as his instead of mine Link to comment Share on other sites More sharing options...
Joe X Posted February 7, 2013 Report Share Posted February 7, 2013 A suggestion for those external dimensions, driver displacement used 0.12 cubic feet per driver, two common walls:Assumes: for use up to rated power.Enclosure Specifications:Fb = 35.2 HzVb = 5 ft^3External Height = 17 inExternal Width = 36 inExternal Depth = 26 inPort Width = 6 inCut Sheet List:* All Dimensions in Inches.* Wood Thickness is 3/4 for all Parts.External Enclosure Parts:2 x Top & Bottom (3 parts) = 36 x 26Left & Right Sides = 24 1/2 x 14 3/42x Front = 15 x 14 3/4Back = 36 x 14 3/4Shared Port Internal Assembly Parts:2 x Front to Back = 21 1/2 x 14 3/4Assembly guide (generic dimensions): - The 45s if you want to do them are 2 1/2" wide except the one/ones inside the port, if you want that let me know.- The port needs 6" of free airspace in front of it for proper operation.- Setting your amp's subsonic filter to 28Hz is suggested. Link to comment Share on other sites More sharing options...
mnrookie Posted February 7, 2013 Author Report Share Posted February 7, 2013 Sorry, forgot to mention its going to be in a 93 yukon being run by an aq1200 Link to comment Share on other sites More sharing options...
stroupe79 Posted February 7, 2013 Report Share Posted February 7, 2013 was gonna say AQs love the port...and 13in per cube is a bit low for them...Joe X hooked you up, as usual... http://www.stevemead...cherokee-build/ 2005 Jeep Grand Cherokee Alpine CDE-hd148bt Alpine PKG-RSE2 PRV Audio (4) 6MB200 front/rear doors PRV Audio (4) TW350Ti dash/rear doors Kicker KX350.4 Obsidian Audio (1) 18 D4 v2 revamp (2) Stereo Integrity HT 18d2DC Audio 1.2k5.25ft^3 tuned @34hz revamp Infinite Baffle Cpillar AudioTechnix 60mil deadenerKnuKonceptz & SkyHigh wire (complete setup) Link to comment Share on other sites More sharing options...
Joe X Posted February 7, 2013 Report Share Posted February 7, 2013 Sorry, forgot to mention its going to be in a 93 yukon being run by an aq1200 Changed for a SUV type box, the double baffle is not strictly necessary. Link to comment Share on other sites More sharing options...
mnrookie Posted February 7, 2013 Author Report Share Posted February 7, 2013 Great, thanks for the help. It was my first time using torres so I still have a lot to learn. Link to comment Share on other sites More sharing options...
