sbg Posted February 7, 2013 Report Share Posted February 7, 2013 I just put my amp in today (bb2400.1) so it worked fine on the way to work, and worked fine for a few times today. But I was getting a lot of volt drop.. So I get off work and start driving home, and the amp turns off for a sec and I see that my factory battery volt meter is way low! Ok so it turns back on and is working and I have it vary low volume and am like ok I'm not going to push it.., so I'm driving like 1 min later and I'm not even playing the subs hard at all like volume of 10 on my HU and I see my volt meter go way down again and then I smell the stink! But it's not real bad. Then no more sound. I go home and check out what'd going on and the amp still has power and the green light is on but still no sound! So I take it in side and take it apart and I see no Burt board parts at all! I did have to fix the RCA 1 time in this amp but it looks to be still fine from the 1st fix. So what I need to know is can the volt drop have some how killed the sound? 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca Link to comment Share on other sites More sharing options...
sbg Posted February 7, 2013 Author Report Share Posted February 7, 2013 yes and the bb2400's are very power hungry. what did you have electrical wise 130 amp stock alt and big 3 in 4 ga and PGA run to the back 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca Link to comment Share on other sites More sharing options...
sbg Posted February 7, 2013 Author Report Share Posted February 7, 2013 I know what I need! I had planed on doing some more stuff to help. My question is, is my amp dead now? Like I said it still has power and is not in protect, just does not have sound now? 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca Link to comment Share on other sites More sharing options...
sbg Posted February 7, 2013 Author Report Share Posted February 7, 2013 I know what I need! I had planed on doing some more stuff to help. My question is, is my amp dead now? Like I said it still has power and is not in protect, just does not have sound now?and I took the board apart and there is not burnt parts at all. 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca Link to comment Share on other sites More sharing options...
Jessica Posted February 7, 2013 Report Share Posted February 7, 2013 post pics of said board Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
sbg Posted February 7, 2013 Author Report Share Posted February 7, 2013 post pics of said boardlet me go get some pics 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca Link to comment Share on other sites More sharing options...
Skullz Posted February 7, 2013 Report Share Posted February 7, 2013 Might have blown the subs. Wiring might have come disconnected. You'll need to check everything out before you tear into your amp, as it may not even be the problem. Go through and make sure everything works, IE using the amp with another sub to make sure it works. Check the subs with a dmm and make sure the coils are in good shape and not blown or shorted out. Make sure all wiring is solid and not causing a possible problem, mainly the ground. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2 Link to comment Share on other sites More sharing options...
sbg Posted February 7, 2013 Author Report Share Posted February 7, 2013 http://i1153.photobucket.com/albums/p514/sbg24231/5035CC58-78EC-4393-8CA4-96BF2B0AB2C9-5485-0000039F3DD1A582_zps9fb96d4e.jpghttp://i1153.photobucket.com/albums/p514/sbg24231/8D936C58-F938-4D23-9A9F-772D7E7966A3-5485-0000039F41D9BB1F_zpsd921655a.jpghttp://i1153.photobucket.com/albums/p514/sbg24231/2B118258-C8F8-4FDC-AE2C-7BC3847D965B-5485-0000039F45879155_zps7f3cf239.jpghttp://i1153.photobucket.com/albums/p514/sbg24231/151EDC16-2519-4071-971A-4F4B32ED68B8-5485-0000039F48BB01A3_zpsa9559f10.jpghttp://i1153.photobucket.com/albums/p514/sbg24231/8BEC0D99-6E54-4B04-BBBA-1CD1C1DBA449-5485-0000039F4C89A74F_zpsef495939.jpghttp://i1153.photobucket.com/albums/p514/sbg24231/33A1658F-1340-473B-AD63-79DA13069E02-5485-0000039F4F532620_zps30a3bdaf.jpghttp://i1153.photobucket.com/albums/p514/sbg24231/33A1658F-1340-473B-AD63-79DA13069E02-5485-0000039F4F532620_zps30a3bdaf.jpghttp://i1153.photobucket.com/albums/p514/sbg24231/6C71C505-3ED0-4755-8FBC-8B6A77663B04-5485-0000039F52E18C35_zps725e5a47.jpg 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca Link to comment Share on other sites More sharing options...
sbg Posted February 7, 2013 Author Report Share Posted February 7, 2013 no picim on my cell right now... Give me a sec it's a big ass board and hard to get good pics 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca Link to comment Share on other sites More sharing options...
sbg Posted February 7, 2013 Author Report Share Posted February 7, 2013 http://i1153.photobucket.com/albums/p514/sbg24231/5035CC58-78EC-4393-8CA4-96BF2B0AB2C9-5485-0000039F3DD1A582_zps9fb96d4e.jpg 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca Link to comment Share on other sites More sharing options...
