def loudness Posted February 9, 2013 Report Posted February 9, 2013 Is it wise if l've got a second battery in the back to run a second 0ga (negative) back to the under hood neg post on the battery?..I currently have big 3, but back battery neg is just bolted on chassis. If I ran it back to underhood battery neg, would I see a volt difference?
michigancapri92 Posted February 9, 2013 Report Posted February 9, 2013 yes !! your electrical still has to work its way to the front of the car ... if you have the back battery grounded to the back it relies on the car body to work its way up which can consist of just small spot welds ... sooo if you use a full 0awg run the electrical can easily get back to the front of the car! Teamcapri.comThe TeamCapri 1992 Mercury Capri XR22012 FORD EDGE SQ BUILDOld build logMy FeedBack1992 Mercury capri XR2 Hyper LED
Omega5002 Posted February 9, 2013 Report Posted February 9, 2013 Your battery would better grounded if you did that, there's nothing wrong with doing that (actually gonna do that when I get around to getting a 2nd battery myself) 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick)
FrontierGello Posted February 9, 2013 Report Posted February 9, 2013 http://www.stevemeadedesigns.com/board/topic/147995-ground-to-the-chassis-or-run-a-ground-cable-ce-auto-electric-supply-partners-with-damore-engineering-to-answer-video-on-pg-5/ Nissan Frontier 10" Cadence Midbass 8" Cadnece Midrange Bullet tweets 2 Re audio Sxx 15 Subs Mechman 270a 2 Re XT4000deV3 mono 1600 rms 1 Re XT400deV3 Bridged 350x2 2 Cadence 175.4 Bridged 350x2 Audiomaxx and Stinger 0,4,8,12 awg wires Dynamat sound deadeners My Build Log: http://www.stevemead...__+1999 +nissan
def loudness Posted February 10, 2013 Author Report Posted February 10, 2013 Thanks guys...I'll do it vrry soon
