pontformulalt1 Posted February 12, 2013 Author Report Share Posted February 12, 2013 Couldn't you just cap the one amp the protects since none of the others are affected? Just my thought. I have no experience in this area tho. So I could be wrong. i have about (5) 1 fared caps laying around i think i might just try this....this is the interior amp that is shutting down and is not a big amperage hog as i would think its only pulling about 50 amps putting out around 100x4 on peak Link to comment Share on other sites More sharing options...
KiKaZz74 Posted February 12, 2013 Report Share Posted February 12, 2013 Alright. Cuz what I seem to understand from here is caps even out little spikes in voltage IF you have the electrical to back it up. And it sounds like you do so I think this could work for spikes as well as dips. Try it and let us know bro! My SPL to SQ Build Log Vehicle:1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT5.2L V8 Magnum 3.5L V6 Stock AltEquipment: Headunit- Alpine CDE-147BT Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12 Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy Mids- Dayton Audio Reference 4" Full Range Drivers Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5" Processor- MiniDSP 2x4 RCA- 6 channels of SounDrive HF series Wire- EB Flex 2/0 -Member of Team SounDrive Link to comment Share on other sites More sharing options...
pontformulalt1 Posted February 12, 2013 Author Report Share Posted February 12, 2013 i really like the 14.6-14.8 charging voltage i have it really makes a difference when you start to slam the sounds as my amps put out the true r.m.s. output @14.1..it is really noticable when the volotage is up and you spin that mechman @ about 1500-2000 r.p.m. its just the spike in between the bass drops of pulling close to 600 amp current draw to nothing and it throws that alt. close to 16.0 volts till it finds it correct chargeing voltage Link to comment Share on other sites More sharing options...
pontformulalt1 Posted February 12, 2013 Author Report Share Posted February 12, 2013 Update......I just took a ride to the store and popped my hood prior to leaving and hooked up the dmm and tuned the mechman avbm down to 14.2-14.5 which I think is about what it puts out without the avbm very minimum shut down Link to comment Share on other sites More sharing options...
pontformulalt1 Posted February 12, 2013 Author Report Share Posted February 12, 2013 I'm seeing about a 14.2 charging voltage sitting here @ about 220 degrees engine temp...and about 14.5 driving while the engine is around 200 degrees driving with 35 degree ambient temp here...seems the mechman likes the cooler temp as I visually see the voltage increase as the engine cools as I drive....I might add as I have a f-body car and has no grill it is under bumper cover cooled by an air dam Link to comment Share on other sites More sharing options...
ChevyBoy95 Posted February 12, 2013 Report Share Posted February 12, 2013 All alts charge higher when colder, there are exceptions but that happens below freezing generally. Hot I charge 14.1, cold 14.7. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/ Link to comment Share on other sites More sharing options...
