pontformulalt1 Posted February 10, 2013 Report Posted February 10, 2013 I am running a 320a alt. And (5) amps (2) zxs1500.1, (2) zxs1000.1 and a 650.4. Charging voltage is at 14.8. The problem I'm haveing is when I'm slammin at full tilt in between the bass drops my voltage goes up for a split second to 15.5-16.0 volts and is only shutting off the zx650.4.does anyone know where this over-voltage protection circuit is and how to disable it
SnowDrifter Posted February 10, 2013 Report Posted February 10, 2013 It's not just a "thing" you can go in and disable. Someone else who is more knowledgeable about amps will chime in, but as I understand it: the power supply of an an amp has a working voltage, both a minimum and a maximum. You go outside of these ranges and the amp goes poof. The protection circuit shuts the amp down before this happens. You could add some caps/batteries to stabilize that voltage spike ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
Kyblack76 Posted February 10, 2013 Report Posted February 10, 2013 This is a legit problem... There are a few things you can do. Some i dont want to be on the hook for....... But, i know i myself, ive ran into this issue of high voltage BUMPS, shutting down my amps...... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
SnowDrifter Posted February 10, 2013 Report Posted February 10, 2013 You could also look into getting a different amplifier, or getting a stepdown converter or something to regulate the voltage at 14.4. Or potentially switching to external regulation for your alt, since I'm pretty sure those are much more stable than stock ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
RooTxBeeR Posted February 10, 2013 Report Posted February 10, 2013 OR get the mechman AVBM, and regulate your voltage to a maximum of 14.8 On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5
pontformulalt1 Posted February 10, 2013 Author Report Posted February 10, 2013 I am running an optima red-top up front and (3) kinetik 1400's in the back maybe more reserve would filter this voltage spike?
Kyblack76 Posted February 10, 2013 Report Posted February 10, 2013 I am running an optima red-top up front and (3) kinetik 1400's in the back maybe more reserve would filter this voltage spike? This very very well could work. And would be my first choice of action. The water (demand) would pour into such a small shot glass, it would over flow, ...... SPIKE Get a bigger glass to catch the pour.... I had the SAME issue, and adding more bank was the cure. It seemed to spread the demand. And if im talking shit or not, it worked for me...?? No more amp killing spikes. It is where i would go, if i was you..... If you get a AVBM, i experianced id have to set it where the spike would NOT affect the amps, but, then, it would be to "low" in order to reach full output. Do i make sense? To not see the here and there SPIKE, i wouldnt see full output. Hope im saying that where you understand. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
pontformulalt1 Posted February 10, 2013 Author Report Posted February 10, 2013 I am currently running the mechman avbm set @ 14.8
SnowDrifter Posted February 10, 2013 Report Posted February 10, 2013 OR get the mechman AVBM, and regulate your voltage to a maximum of 14.8 I am currently running the mechman avbm set @ 14.8 The AVBM is not the same as a true external regulator. All it really does is trick the car's computer into thinking the voltage is lower then it really is, so it will compensate by raising it. OPs issue is that the car's computer takes a second to reduce the field current going to the alt, and in that second while the alt is running at X capacity, but the load is less, the voltage will spike ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
pontformulalt1 Posted February 10, 2013 Author Report Posted February 10, 2013 I am running an optima red-top up front and (3) kinetik 1400's in the back maybe more reserve would filter this voltage spike?This very very well could work. And would be my first choice of action.The water (demand) would pour into such a small shot glass, it would over flow, ...... SPIKE Get a bigger glass to catch the pour.... I had the SAME issue, and adding more bank was the cure. It seemed to spread the demand. And if im talking shit or not, it worked for me...?? No more amp killing spikes. It is where i would go, if i was you..... If you get a AVBM, i experianced id have to set it where the spike would NOT affect the amps, but, then, it would be to "low" in order to reach full output. Do i make sense? To not see the here and there SPIKE, i wouldnt see full output. Hope im saying that where you understand. this makes complete sense good way of describing it. Thanks for the input
