96 DemoCCord. 150@32hz in a trunk + 3way SQ front stage
damn nice build man!
Thanks bro. I worked hard on it and did everything myself except for the box. Learning as I go. I hopped people wouldn't call my build shitty when I made a build log!
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
Thats all for now folks... Stay tuned for my wall :peepwall: any guesses on what im running?
4 zvx 12"s?
Good guess. I'm thinking 4 ZVX 12's on 2 2500.1 in a BHE wall. 3 or 4 Xs batteries... Lots of toolmaker stuff. More OFC stuff instead of my mostly CCA wire... And a shit ton more deadener. Still figuring out what I wanna do with my doors.
That'd be pretty aggressive lol. Nice build by the way!
Appreciate it bro! Yeah I'm not sure when I'm gonna attempt it... I think I'm just gonna pile up the equipment as I find it on sale for good $$ and then scoop it up.. When I got all I want just shoot over and spend a couple days in Tampa at robin from BHE's house
No problem. Thats the way to go! You can get stuff for pretty cheap used. Just wondering did you ever have the 2500.1 hooked up to the vvx's?
Those were d4 ohm coils... Paralleled down to 1 ohm nominal.. Set at -5 db with my DD1. They worked hard but sounded great.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
Nice build man! Looks clean.
Thanks bro! Much appreciated. I wanted it to look like a completely stock accord till I fold the seats :) I guess I accomplished that pretty good. Coulda done some things better but I learned a lot
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
Sweet build! Robin and Chris @ BHE do work! Can't wait to see what you do when you wall it.
I hear you. Robin is a cool guy. I gotta address my weight issues..l then I'm gonna wall it and i hope it will be petty nasty :)
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
why wall with 4 12's? don't the skar's like small boxes? seems like 4 15's is easily doable in a wall in an accord
nevertheless, seems like it gets down
They are pretty efficient on space yes... 1 cube sealed and 2 cubes ported for my ZVX 12.... I have a 4.x cube box kerfed port tuned to 31.xx... The reason I'm walling with 12's is because of 2 things.l.
1) I have 12's and won't have to recone. Plus the way the coils are I can strap 2 2500's at 2 ohm nominal (1ohm each amp) with my 4 d1 ZVX's so that works out good.
2) the 15's want much more airspace and I don't know if I want to give it up. I'm 6'3" and I like my seat really far back :) just sayin
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
I wan't to see how much room you have once you get the seat out. My accord is ity-bity. Only room for 4 -12's but that's just cause of width and height restricitions.
I haven't measured it out yet but I'm thinking air space and the fact that I don't wanna give up leg room. I don't mind having a 2 seater but ill be damned if I'm gonna drive my car scrunched up because of bass.... Ill just use 12's not 15's lol
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
naww i dont like you have little power you need MOREEEEE lol hahah looks good bro i have seen it in person and for a 2,500 rms amp it does work for them 2 zvx
2010 Mazda 3
*Rebuild Time*
Subs - (2) AA Mayhems 12's
Sub amp - (1) Populus Audio TPA 6500
Headunit - Pioneer App Radio 2
Batteries - XS Power (1) D3100 up front | 6 XP950 rear
Wire - Sky High 1/0 Gauge wires and RCA's and steve's VM1
Alternator - Singer 260 Externally Regulated
Front Stage: (2) PRV Audio 10W650A (4) PRV Audio 8MR500-PhP-4 (4) DS Bullet Tweets | (2) 6.5 Components (Rear doors)
Mids & high Amp : (2) Populus Audio 100.4
Processor: Rockford 3sixty.3
The Build Log : http://www.stevemeadedesigns.com/board/topic/175922-2010-mazda-3-2-aa-mayhems-12-pg14-new-video/page-11
Thanks bro. Oh guess what.... I found those rattles we were hearing that one night outside my dads shop when my neighbor came out and started talking how his mtx 10's and 1800 watt boss amp was louder then my car LOL...
in my spare tire well was a whole bunch of broken glass screws and stuff that was vibrating against the bare metal in my tire well were the spare is... No more rattle there now :)
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
Everything looks good man! What size port are you working with? Looks big! Not saying that's bad, just saying. I'm about to build one for 2 12's at 4" wide and that thing looks like it's more around 6 wide. Looking forward to more!
That's a kerfed port bro. It's actually less then 3 inches wide in the tunnel parts...but the inside you can see the flared port and the outside its a nice kerf painted black. The of section is prob 3 inches wide plus the 3 inch wide port. Take a second look. My box is less then 32 inches wide and that's the only way he could fit 2 12s flat and still fit a port
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
  • Who's Online   0 Members, 0 Anonymous, 886 Guests (See full list)
