gibblegeibel Posted February 11, 2013 Report Posted February 11, 2013 I'm looking to get another battery for my audio system. but I'm not sure what size or how big to go. i have Hifonics Brutus brz1700.1d amp for the sub. then I'm looking later down the road on get a hifonics glx60.4 amp. i have been looking at a couple different batteries. can some one help? also has any one used the c&d high rate batteries? are they just as good as kinetic or other name brand batteries? please help
bumonskateboard6 Posted February 13, 2013 Report Posted February 13, 2013 I run XS and XS, they aren't the cheapest, but they work. Honestly with the setup you plan on running you probably will be fine (unless you're running that amp at some low impedance) with a stock electrical and when you get the chance just buy a nice XS for a replacement battery up front. Current Systems: 2011 BMW 335i Hertz HDP1 DC LVL3 12" Full Carbon Fiber 2002 Acura TlKenwood DNX9980HD2 DCLVL4 12" Subs with LVL5 Parts D.7 CoilsDC 3.5kHertz HSK-165 up front HCX-165 RearHertz HDP4 AmpDC Power Engineering 260 Amp AltBig 3 and amp powered with KNU 1/0XS Power D2400 Up Front i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch... going over rms = smaller box, under rms = bigger box... Low voltage doesn't blow amps. That's a myth. A router that does the sub holes makes rounded edges also?
Watch the bass Posted February 13, 2013 Report Posted February 13, 2013 I'm looking to get another battery for my audio system. but I'm not sure what size or how big to go. i have Hifonics Brutus brz1700.1d amp for the sub. then I'm looking later down the road on get a hifonics glx60.4 amp. i have been looking at a couple different batteries. can some one help? also has any one used the c&d high rate batteries? are they just as good as kinetic or other name brand batteries? please help Here a nice AGM-batt offer out of the Hot-deal section http://www.stevemeadedesigns.com/board/topic/144556-dont-seem-like-a-bad-deal/, but please don´t mix lead acid with AGM batt´s. "in the abundance of water, the fool is thirsty" Bob Marley
