Mareze Moore Posted February 12, 2013 Report Posted February 12, 2013 im new to fourms so sorry if this is a repost or in the wrong spot im building a custom box 4.65 ft3 for two sa-12 going to be powered by either hifionics brz1700 or glx1800 I want to be loud but also sound good. what is a good tuning I was thinking around 37hz. also I was wanting a divider in the middle but also ported there kinda like labrynith or should I go with a different type of porting
ToNasty Posted February 12, 2013 Report Posted February 12, 2013 I'd.go 32-35 htz. Shrink the box.just a hair. As close.to 4 cubes as.you.can get. 4 cubes net ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
Joe X Posted February 12, 2013 Report Posted February 12, 2013 what about the porting What vehicle is this going into?
Joe X Posted February 12, 2013 Report Posted February 12, 2013 So here is a suggestion to build (checking dimensions first) or as reference for doing your own: Enclosure Specifications:Fb = 33 HzVb = 4 ft^3External Height = 16.5 inExternal Width = 34 inExternal Depth = 21 inPort Width = 3 3/4 inCut Sheet List:* All Dimensions in Inches.* Wood Thickness is 3/4 for all Parts.External Enclosure Parts:2x Front = 15 1/8 x 15Back = 34 x 15Left & Right Sides: 19 1/2 x 15Top & Bottom = 34 x 21Shared Port Internal Assembly Parts:2 x Front to Back = 17 5/8 x 152 x Extension = 4 5/16 x 15 Assembly guide (generic dimensions): - The 45s if you want to do them are 2 1/2" wide except the one/ones inside the port, if you want that let me know.- All trunk boxes built outside the car need to fit in their way in not just have the right dimensions.- The port needs 3 3/4" of free airspace in front of it for proper operation.- Setting your amp's subsonic filter to 28Hz is suggested.
Mareze Moore Posted February 12, 2013 Author Report Posted February 12, 2013 I already have dimensions height 16.5 width 34 depth 18 also wouldn't tuning higher get more spl
ToNasty Posted February 12, 2013 Report Posted February 12, 2013 Take the dimensions Joe says. Your.dimensions.were to big and.Joe.knows what he's doing ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
Joe X Posted February 12, 2013 Report Posted February 12, 2013 I already have dimensions height 16.5 width 34 depth 18 also wouldn't tuning higher get more spl Ok so I have used your dimensions, a little deeper to meet the 4 cubic feet net, the box is tuned to 33Hz so it will be good for music.
ERICROCKFORD Posted June 29, 2013 Report Posted June 29, 2013 So here is a suggestion to build (checking dimensions first) or as reference for doing your own: Enclosure Specifications: Fb = 33 Hz Vb = 4 ft^3 External Height = 16.5 in External Width = 34 in External Depth = 21 in Port Width = 3 3/4 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: 2x Front = 15 1/8 x 15 Back = 34 x 15 Left & Right Sides: 19 1/2 x 15 Top & Bottom = 34 x 21 Shared Port Internal Assembly Parts: 2 x Front to Back = 17 5/8 x 15 2 x Extension = 4 5/16 x 15 Assembly guide (generic dimensions): - The 45s if you want to do them are 2 1/2" wide except the one/ones inside the port, if you want that let me know. - All trunk boxes built outside the car need to fit in their way in not just have the right dimensions. - The port needs 3 3/4" of free airspace in front of it for proper operation. - Setting your amp's subsonic filter to 28Hz is suggested. Joe x I really like this box im thinking im going to build this and put it in my 2001 grand am I have sundown 2 sa-12 and use a Rockford T1500.1 bdcp running @ 1ohm the size of the Box looks great for a fit in my car but is there any changes you would make to this with the power of the amp birth sheet of my amp says 1927 W
