im in the process of hopefully getting a 1999 Gmc Yukon. Now my question is, is the factory radio double din or 1.5 din? If its 1.5 does anyone have pictures of how they "easily" fit a double din?
C-Fizzy, on 01 April 2012 - 01:06 PM, said:
Clip city bitch, clip clip city bitch. 10's, 12's, 15's, goin up in flames bitch.
Check out my build thread http://www.stevemead...product-page-2/
New build
http://www.stevemeadedesigns.com/board/topic/172646-punkrocks-97-civic-build/
It's single din.. It takes alot of modification to fit double din
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
1.5 din.
search around, plenty of people of done it. I was going to do a ipad in my 97 burb, still might one day
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
Looks manageable. Buy double din dash kit and mold it to factory dash and bondo and paint huh??
New build
http://thedetailss.com/ the best kit for DD conversion. I just used SP glue to hold in place and body filler to fill in the gaps.
and what happens when it cracks?
I forgot what a stock bezel looked like.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Like I said it can be done .. Hardest part is bezel work which is tedious .. Also dd unit isn't really securely mounted so easy to steal
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
Would you guys recommend doing it?
New build
I did mine a couple months ago. It's a good Kit. It does have a steel Double din mounting bracket. Very good instructions. Just take your time cutting the bezel. It's holding up pretty good no cracking at 150.3 db @ 31hz.
Can you pm me step by step instructions on how to do it? Lol pictures would help alot too
New build
  • Who's Online   0 Members, 0 Anonymous, 3650 Guests (See full list)
