(blown sub?) Solved
SlamminBeats
So of course my 9512 decided to cut out on me and wont go back on. I took it out of the box and tried running tones/music through out side of the box; nothing.... I tried just hooking up one coil at a time....nothing. The soft parts are fine. WTF could be wrong. There was no smell when it cut out, and i was playing a safe song right at tuning that i have played many times before.
PS: When both subs are hooked together in series before the amp, neither works.. When i take away the shit one, the other works alone....hmmmm
Is the resistance on the coil reading fine?
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
Check where the tinsel ia wove. Into the spider is it touching the basket
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
do the coils read fine? look at the amp with both subs hooked up and see if it's in protect, my guess is a broken tinsel lead on one sub causing the amp to go into protect
'93 Firebird Formula V8
H/U- Kenwood eXcelon KDC-X395
Mids/Highs Amp- Hifonics ZXI80.4
Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0
G34 Red Top and a 180amp Ford Alternator
www.youtube.com/TRTC360
amps never went in to protect
both amps work because i used another subs to test that.
this sub just cut out super abruptly and has no response at all.
what I found when i reconed mine is if you pull the direct leads down too far you end up with them touchign the basket. It will show a dead short to your amp dead short. no sound gets played.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
  • Who's Online   1 Member, 0 Anonymous, 1431 Guests (See full list)
