dblovah51 Posted February 14, 2013 Report Posted February 14, 2013 Hi i know many ppl on here has TB, have any of you guys come across ride continuously shutting off at low speed or acceleration? as i come off the gas pedal the rpm dips low n back up, as i step on the pedal the truck hesitates like and sometimes dies out completely,but starts right away. everyone says clean throttle body but honestly seems like the problem began after i cleaned my throttle body. HELP before i get rid of this defect on wheels!! 2004 trailblazer 4 FI BTL 18s (2) DC 10.0k xs power d3100s mechman 270 158.2 @41
SoCaLBaMF Posted February 14, 2013 Report Posted February 14, 2013 Mine did that when I turned on the A/C but sorted itself out after a while. Took it to a dealer and they had no clue what it was. 2004 Bagged Trailblazer (4)18" Sundown Nsv3s (4) Taramps HD10000s, Taramps DSP3000, Lanzar opti 250x2, AB 100x4 (2)DC power SP 270s, (14)XS Power d3100s, (1)d6500
WhiteTB Posted February 14, 2013 Report Posted February 14, 2013 Whens the last time you cleaned the throttle body? If never i bet that's the problem . Its cheap and easy to do. http://www.youtube.com/watch?v=VdvgsaDmkac http://gmtnation.com/content/how-clean-4-2-i6-throttle-body-120/ Team DOA Team gg
SoCaLBaMF Posted February 14, 2013 Report Posted February 14, 2013 He said the problem occured after he cleaned it. 2004 Bagged Trailblazer (4)18" Sundown Nsv3s (4) Taramps HD10000s, Taramps DSP3000, Lanzar opti 250x2, AB 100x4 (2)DC power SP 270s, (14)XS Power d3100s, (1)d6500
WhiteTB Posted February 14, 2013 Report Posted February 14, 2013 He said the problem occured after he cleaned it. Guess i should read the whole post first. Your issue sounds like the throttle body issue. Id go back and make sure everything was put back right. Did you disconnect the battery or pull the fuse to reset the pcm? Sign up for gmtnation.com and ask those guys there. They are very helpful Team DOA Team gg
dblovah51 Posted February 16, 2013 Author Report Posted February 16, 2013 Yea SOCAL I was hopin mines would fix itself after a while bein tha ppl ay the pcm has to relearn the idle position after disconnectin the battery to clean throttle body but seems to b getn worst of I'm just more annoyed 2004 trailblazer 4 FI BTL 18s (2) DC 10.0k xs power d3100s mechman 270 158.2 @41
dblovah51 Posted February 16, 2013 Author Report Posted February 16, 2013 The throttle body was cleaned last mnth and left battery disconnected for a while like most ppl suggested. I haven't seen anyone have this issue fixed after doin many research TB seems to hve some many flaws its sad that I have 2 of them lol 2004 trailblazer 4 FI BTL 18s (2) DC 10.0k xs power d3100s mechman 270 158.2 @41
95legwagon Posted February 17, 2013 Report Posted February 17, 2013 the only thing i can say to tr to help to diagnose a little further is when its about to die throw it in neutral and rev it..... if it dies something else is wrong.....let us know here. also try cleaning the idle air control valve i think there real i was looking through that guys stuff he sells and it looks like he finds stuff at auctions and just sells it Yea, it looks like someone got the mids about a month ago....shit. If I had a whole Hertz front stage my ears would jizz all over my cheeks. / LOL My Low Budget Build: Green 1995 Subaru Legacy wagon 147k- $1K headunit- pioneer premier deh-p650-$25 4 Lead acid batts. 1 up front and 3 in back- vented outside.- $50 4 vvme L11 10"s <- $30 shipped a piece 6 cu. ft box (after displacment) tuned to 32ish hz with 10 inch sonotube. -about $50 all together maybe a lil more 2 aspm 1300 strapped Selenium 6"s in the front doors on headunit power- for now -$20 quantum tweets in door-for now -$10 boston acoustic 5 1/4 in rear doors- for now-Free big 3 1/0 and 4awg throughout. roof sound deadened (not peel n seal ftw)-free on 80 amp alt (bench tested to put out 100 amps faithfully) <--?-$10 for test about $430 for everything<----Not bad at all still gotta add 3 way crossover, amp for front and rear door speakers and maybe eq
dblovah51 Posted February 19, 2013 Author Report Posted February 19, 2013 95 when its about to cut out and I rev throw it in nuetral it catches itself instanly, if I slightly taps the gas then it cuts off. The idle dips below 400 and shut off 2004 trailblazer 4 FI BTL 18s (2) DC 10.0k xs power d3100s mechman 270 158.2 @41
I.V Posted February 19, 2013 Report Posted February 19, 2013 check the mass airflow sensor or gas pump 06 Trailblazer ss2 Team shok industries tsx 18sPhoenix Gold ''THE ONE''2 Phoenix gold 800.44 crescendo mp6.2 crescendo mp8bass processor Dc power 270xp 150ft 1/0 ofc sky high cable1 juicebox lithium 0.5kwh 14v/40ahkenwood dnx8120BCAE1.com YouTube channel : REaudioxxx1build log: http://www.stevemeadedesigns.com/board/topic/160106-trailblazer-ss-xxx/
