djscrappydee Posted February 14, 2013 Author Report Posted February 14, 2013 Hope someone chimes in and helps out cause this sounds like shit lol (2) PSI p2 18's Crescendo 2000 Audio Technix 0 gauge/ SHCA 0 gauge Pioneer AVH-P2400BT yellow top optima big 3 . xs batt.
Raptorman Posted February 14, 2013 Report Posted February 14, 2013 I had a hinge on my trunk that would rattle (or sound like it) when anything below 27hz would hit. Surprisingly all that took to fix it was some WD-40 on the hinge. Check if it's anything like that. Or the door seals could be leaking? 1996 GMC Sonoma Four Fi BTL Neo 18's In 2:1 6th Order Bandpass 2 Ampere 5k's @ .5 TEAM FI TEAM #LITHIUMCANTDEMO On 10/20/2013 at 0:37 AM, KillaCam said: Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
stroupe79 Posted February 14, 2013 Report Posted February 14, 2013 what kind of deadener are you currently running?...you might need to upgrade to a higher quality deadener and see how that works http://www.stevemead...cherokee-build/ 2005 Jeep Grand Cherokee Alpine CDE-hd148bt Alpine PKG-RSE2 PRV Audio (4) 6MB200 front/rear doors PRV Audio (4) TW350Ti dash/rear doors Kicker KX350.4 Obsidian Audio (1) 18 D4 v2 revamp (2) Stereo Integrity HT 18d2DC Audio 1.2k5.25ft^3 tuned @34hz revamp Infinite Baffle Cpillar AudioTechnix 60mil deadenerKnuKonceptz & SkyHigh wire (complete setup)
djscrappydee Posted February 14, 2013 Author Report Posted February 14, 2013 Dynamat and audio technix 60 mil I think it is. And I don't think it is a hinge. I no I can get out and push on the door right by the crack and its not that loud anymore (2) PSI p2 18's Crescendo 2000 Audio Technix 0 gauge/ SHCA 0 gauge Pioneer AVH-P2400BT yellow top optima big 3 . xs batt.
RMac18 Posted February 14, 2013 Report Posted February 14, 2013 Is the noise coming from the door itself or is it flexing and what you hear is the door rattling against the door jam? If its the door itself try to isolate the area that is rattling and maybe double up the sound deadener or use the the expanding foam. If its the full door against the door jam, you could check and possibly replace the weather stripping on the door.
djscrappydee Posted February 15, 2013 Author Report Posted February 15, 2013 It's the full door (2) PSI p2 18's Crescendo 2000 Audio Technix 0 gauge/ SHCA 0 gauge Pioneer AVH-P2400BT yellow top optima big 3 . xs batt.
djscrappydee Posted February 15, 2013 Author Report Posted February 15, 2013 Also the window does it baaaad too. I tried to wedge card board in between it to stop it from slapping the door. Imma try to wedge more in it (2) PSI p2 18's Crescendo 2000 Audio Technix 0 gauge/ SHCA 0 gauge Pioneer AVH-P2400BT yellow top optima big 3 . xs batt.
Tebo Posted February 15, 2013 Report Posted February 15, 2013 Audiotechnix 80 mil then spray foam it 04 dodge dakota ext cab 4x4 excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator
