6 speakers on a 4 channel amp?
are the T165s the T652s or T1653? should be T1652 right?
Those T1693 are going to scream with Highs, my son has a set of T1692s and i like the woofer tweeter set up better and there loud as hell. I run the T1652 in the rear deck of a 03 Lancer and the sound stage is horrible. going to relocate some T2s in rear doors. Just not sure if its going to be 5.25s or 6.5s. i am running 2 t400-4 amps & one is dedicated to the T165 comps in my front doors.
I learned alot in the last 8 weeks since i finished my build and plan on re-doing it for a more SQL set up. sub stage is great but need more mid range and mid bass up front. many get rid of the sound stage coming from so high up in the back and bounce off rear window and firing forward.
assuming you are using the 6.5s up front and the 6x9s in the rear, wire each pair up front in parallel (2 ohms final). hook the left side to the front left channel the right to the front right channel. then just hook the 6x9s to the corresponding rear channel. hope this wasnt to hard to comprehend, i'm in a rush and had to help! let me know if you have any questions.
[sharedmedia=garage:vehicles:2223]
CAFForumSig_zps376518ed.jpg?t=1364077982
SD, thank for the input. I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
  • Who's Online   0 Members, 0 Anonymous, 1070 Guests (See full list)
