i have a question i have 2 alpine type r 15s in my crown vic with a mtx ta 7801 mono block amp not sure of the rms wattage but they hit pretty hard. BUT i just got a audiobahn a2300hcx 2ch. im not a big fan of audiobahn but i have heard these amps are tight. i know its hella big but that means nothing. i was told that it is #1. 2 Ohm Mono: 1200 X 1 Watts RMS
2 Ohm Mono: #2. 2400 X 1 Watts RMS @ 1 ohm. but my subs are dual 4ohm and i dont know how to wire them at 1 ohm. should i stich with the mtx or just run the other? any positive advice appreciated.
http://www.rockfordfosgate.com/rftech/woof...mp;woofer_imp=4
Use the first one and your set to go with the audiobahn as long as your careful with the gain.
"MY RIDE"
1987 Chevy Cavalier Z24 2.8L V6 -- CB Radio with PA speaker
Head Unit: 7 inch Jensen Flip-out -- Speakers: 4 Visonik 6 1/2s and 4 Visonik 6x9s
Subwoofer: One Audiobahn 18 - Sub Amp: Power Acoustik OV1-2000d 2000 watt monoblock amp --
Battery in back - Kinetic HC600 -- Sub box: Custom built 5 cubic foot tuned to 30 hertz
Coming soon: Bigger Highs Amp, Power inverter
"WhItE bOi AuDiO"
"FEAR THE DUCK"
dont turn it up too high or ull blow ur subs up
oh yea that makes sense now my next problem is that my box has 1 big port in the middle how do i bridge the subssubs004.jpg not sure if the pic will help.
never mind i dont know how to add a pic.
do you have speaker terminal(s) on the box?
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
