gotb00st Posted February 18, 2013 Report Share Posted February 18, 2013 Hello, This is my first time building a box. I would like to hear any thoughts you might have before I get to building. I just recently purchased 2x FI Q 12's dual 1's with cooling, and spider. I designed a box for a 2002 gmc envoy. These subs will be pushed by a Crescendo BC2000D. (May eventually upgrade to a 3500 or 2x 2000's). Box is 5.0 cu ft and is tuned around 32hz. Heres what I came up with. My main concern is if I did the port length correctly and if I calculated the bracing displacement correctly. Link to comment Share on other sites More sharing options...
gotb00st Posted February 19, 2013 Author Report Share Posted February 19, 2013 bump. anyonem Link to comment Share on other sites More sharing options...
gotb00st Posted February 19, 2013 Author Report Share Posted February 19, 2013 bump Link to comment Share on other sites More sharing options...
gotb00st Posted February 20, 2013 Author Report Share Posted February 20, 2013 wow it's hard to get some help around here Link to comment Share on other sites More sharing options...
AK bass Posted February 20, 2013 Report Share Posted February 20, 2013 everything looks good. you wont know how it will sound till you build it. But the port area looks good and the net looks good. "The secret to creativity is knowing how to hide your sources." Albert Einstein Link to comment Share on other sites More sharing options...
AK bass Posted February 20, 2013 Report Share Posted February 20, 2013 and the bracing looks good "The secret to creativity is knowing how to hide your sources." Albert Einstein Link to comment Share on other sites More sharing options...
teamace24 Posted February 20, 2013 Report Share Posted February 20, 2013 Trying to learn myself a little about that port length on torres. How come on the calculator the 'physical port length says 26.75 but the wood pieces you drew up there add up to 22.75(16.75+6)? Im stuck on what the cut sheet should be for the port walls and how to come with the number. 1st Setup(SOLD):2007 GMC YukonPioneer Avic F90bt Audiocontrol Epicenter2 Audioque SDC2.5 15 subs8.7 cubes at 37hz build DONEAudioque 1200d (Audioque 1200d Sold, similar performance to my ap1500)Diamond Audio Hex 6.5 Mids n TweetsCerwin Vega Exl 400 4 channel Bridged(also have MTX 4004 not being used)1 Run of power Knu Fleks 4 Gauge2 Cheap stock Battery setup2nd Setup (SOLD):2007 GMC YukonPioneer Avic F90bt Audiocontrol Epicenter2 15 Kicker cvx (maybe two SA 15 in future)7 cubes net tuned at 34hzAlphasonik Old school 1600rms (ap 1500d sold GREAT Budget amp)JBL 6.5 Power Series Components, Infinity Kappa 6.5 3 ways, and 2 Kicker KS Tweets (LOUD)Cerwin vega exl4001 run knu Fleks OFC 0 gaugeBig 3 done1 Odyssey 1500, 1 optima yellow top d31 Link to comment Share on other sites More sharing options...
gotb00st Posted February 20, 2013 Author Report Share Posted February 20, 2013 I calculated port length by the middle of the port not the port walls. also multiply the the L port by 2 to compensate for both chambers. thats how I understood port length was calculated I may be wrong that was the whole purpose of this post. Link to comment Share on other sites More sharing options...
gotb00st Posted February 21, 2013 Author Report Share Posted February 21, 2013 how about my drawing did i draw the port to match the specs on torres right? Link to comment Share on other sites More sharing options...
gotb00st Posted February 23, 2013 Author Report Share Posted February 23, 2013 Ok I redesigned the box and made the correct adjustments to the port. Does this look correct for actual port length now? Link to comment Share on other sites More sharing options...
