blackandgoldl69 Posted February 19, 2013 Report Posted February 19, 2013 so i am in the process of installing an electric fan on my truck. I know i can go the cheap route and put them on a toggle switch, but I'm afraid i will forget to turn it on. So my question is what all do i need to make the fan kick on by itself at a specified temperature? i know i need a fan temp switch but I'm not sure which one.
barney91 Posted February 19, 2013 Report Posted February 19, 2013 I bought my relay at autozone its a lil kit they sell it kicks on around 180 or 200 I think the kit was like 15 or something like that. What truck do you have and what fan(s) are you using Alpine 9884 RF T2 comp set up front The Epicenter 2x RF T10001bd 2x Sundown sa-15 t-line Big 3 Smd DD-1
bassface Posted February 19, 2013 Report Posted February 19, 2013 You mean like a thermostat switch?.
blackandgoldl69 Posted February 19, 2013 Author Report Posted February 19, 2013 i have a 93 s10 and i got a set of dual fans from a ford tarus and made them fit now i just need them wired up. And i think a thermostat switch is what i need. I was just at autozone and the only thing they said they had was a toggle switch?
barney91 Posted February 19, 2013 Report Posted February 19, 2013 What made you go with the dual tarus. And you should make friends with someone at autozone that knows they stuff ill try to find a link for you. The kit is almost pug and play Alpine 9884 RF T2 comp set up front The Epicenter 2x RF T10001bd 2x Sundown sa-15 t-line Big 3 Smd DD-1
blackandgoldl69 Posted February 19, 2013 Author Report Posted February 19, 2013 went with the tarus fit cause they fit with little effort so they were easy to install. Yeah the guys at auto zone didn't seem to have a clue lol
blackandgoldl69 Posted February 19, 2013 Author Report Posted February 19, 2013 http://www.autozone.com/autozone/parts/Compressor-Works-Electric-Fan-Thermostat/1993-Chevrolet-S10-P-U-2WD/_/N-izmhuZ9peiw?itemIdentifier=267187_9581_0_ Is that what i need?
barney91 Posted February 19, 2013 Report Posted February 19, 2013 There's one better then that it comes with everything, I'm having trouble with autozone ffor some reason I can't find it Alpine 9884 RF T2 comp set up front The Epicenter 2x RF T10001bd 2x Sundown sa-15 t-line Big 3 Smd DD-1
sully Posted February 19, 2013 Report Posted February 19, 2013 You can just use a relay and have them stay on with the ignition. You don't "need" a fancy kit that controls by temp. 2003 Ford F-150 Reg Cab layin body on 26's 2003 Tahoe 3/5 drop on 26's with a 408cid Supercharged engine. 2011 Camaro 2SS 2005 VW GTI Stage II ECU, CAI, 3" turbo back exhaust, FMIC, lowered 2" on some plastidipped 18's 2003 Hayabusa lowered, stretched, cams, nitrous and custom paint
boom50cal Posted February 19, 2013 Report Posted February 19, 2013 You can just use a relay and have them stay on with the ignition. You don't "need" a fancy kit that controls by temp. Second this. Half the time those kits' controller box fuck up from heat and never work right(like the one I had), or they splice into the A/C control wire(also like mine) and won't turn on unless the A/C is on. E-fans are cool if you wanna free up some power from your engine, but they pull your voltage down, remember that when your sitting at a stoplight overheating and risking frying your amp(s). Also, make sure those taurus fans move enough air to efficiently cool your radiator. On 1/4/2013 at 9:31 PM, HatersGonnaHate said: Wow. 184 posts and I think you're a fucking asshole.
