Second batt wiring
When in doubt fuse it... Most people don't fuse in between batteries because runs are so short so half the time it would be hard to even ground out. I would say if you feel comfortable without a fuse between batts don't do it. I don't and I think there are a lot of other users on here that don't either
will it be alright to run the wire from front batt to back without a fuse for a few days till can order one?
(2) PSI p2 18's
Crescendo 2000
Audio Technix 0 gauge/ SHCA 0 gauge
Pioneer AVH-P2400BT
yellow top optima
big 3 .
xs batt.
1. postive to postive... Never postive to neg.
2. if long run of wire fuse both ends.
3.agm battery work with other AGM battery not lead acid , so do not mix!
4.EXTRA! DO not need its just a thought to keep it safe and put a volt meter on both batteries
also make sure all bolts are tight and also have good clean grounds.
thats all i can think of.
some people are douchebags. Ignore em ;) But yeah, dude above answered your question. Positive on front batt. to positive on back batt. Don't need a fuse from batt. to batt., just a fuse from your second batt. to your amp.
Wrong! What happens if there if the wire grounds out on the chassis? please explain
You hook your shit up right and that doesn't happen :) Been running a battery in the front to a battery to the back for about 2 years now, and I've NEVER had a single problem without their being a fuse in between batteries.
-playing with different setups
Sure, If you have to do that... I would personally wait.
i have a fuse in my run from front to back, but i have an escalade with 3 runs. i just didnt want to take any chances. its really up to you. how much exposure are you going to have with the wire? thats what you have to think about.
what you mean by exposure?
(2) PSI p2 18's
Crescendo 2000
Pioneer AVH-P2400BT
yellow top optima
big 3 .
xs batt.
In another thread on the board........and so he said himself.......
http://www.stevemeadedesigns.com/board/topic/162679-dc-50k-with-dual-inputs-do-i-need-4-fuses/
HU: Pioneer AVH-X4600BT
Front Stage: 6 Kicker KS60's-2 Kicker KS6x8's
Back Stage: 6 Kicker KS60's-2 Kicker KS6x9's
Blowthru: 6 Pyle Pro audio 8's, 2 Pyle Pro
Audio 6.5's, 4 Selenium super tweeters
Amps: 2 Kicker ZX1500.1's 2 Kicker ZX850.2's
2 Kicker SX900.2's
Subs 4 DC Soundlab Level 4 12's D1's
Alt: Mechman 270xp 6G
Batterys:Diehard Platinum, 2 Kinetik HC2400's
2 Runs of Stinger HPM 0ga
DC Audio build. Middle of page 4...
http://www.stevemeadedesigns.com/board/topic/130652-96-crown-vic-system-upgrade-4-dc-audio-lvl-4-12s-more-to-come/page-4
Blowthrough build
http://www.stevemeadedesigns.com/board/topic/189217-crown-vic-project-blowthrough/
  • Who's Online   1 Member, 0 Anonymous, 1094 Guests (See full list)
