what would make my setup better
villarob713
What kinda subs u running? I should just get a fi 18
why do you want less cone area? plus 18's in the trunk are tricky to pull off correctly without a shit ton of horrifying trunk rattle.
what car do you have anyways?
U should sell all that stuff and start over.
What do u got thats so special? I would drown u lol
...im sure you cant. dont do that sort of thing "my dick is bigger than yours". it makes you look bad.
Ya right
Subs- 2 kicker cvxs 15
Amp- 1500 watt hifonics
Wires-0g
Deck-stock
Oh look, we got a bad ass over here. :)
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
A corolla lol it already rattles to much. I just blew a alpine type r the other day
i dont see you fitting 2 15's PROPERLY in that trunk. unless they made the trunks bigger. my 3 cube box barely fit through the trunk hole of the 94 i had. unless you use a sawzall and cut metal and fire the port and subs forward and seal off the edges.
Thoes 15 do well for what they are
Idd stick with the 2 you have
And when cash is better get a nice 2k 1ohm stable amp
But first
Install the aftermarket H/U you have
And install a second battery or at least a better up front, then add a second
Do the Big 3 if you haven't already
Check you voltage drop at full tilt and then from that add a alt if needed
Don't east your money on a cap unless its a bat/cap and even then I still would buy one
So upgrades in this order
H/U as u have already
Big 3 if haven't already
Good batt up front + 2nd batt
New box built to what u want to achive
1ohm stable 2k amp(something decent)
Then and only then if still not happy add another sub of new/different subs
But first
Thanks bud ima try that
Wires-0g
Deck-stock
  • Who's Online   0 Members, 0 Anonymous, 1449 Guests (See full list)
