Guest Posted February 25, 2013 Report Share Posted February 25, 2013 What kinda subs u running? I should just get a fi 18 why do you want less cone area? plus 18's in the trunk are tricky to pull off correctly without a shit ton of horrifying trunk rattle. what car do you have anyways? Link to comment Share on other sites More sharing options...
Guest Posted February 25, 2013 Report Share Posted February 25, 2013 U should sell all that stuff and start over. What do u got thats so special? I would drown u lol ...im sure you cant. dont do that sort of thing "my dick is bigger than yours". it makes you look bad. Link to comment Share on other sites More sharing options...
villarob713 Posted February 25, 2013 Author Report Share Posted February 25, 2013 A corolla lol it already rattles to much. I just blew a alpine type r the other day Subs- 2 kicker cvxs 15 Amp- 1500 watt hifonics Wires-0g Deck-stock Link to comment Share on other sites More sharing options...
villarob713 Posted February 25, 2013 Author Report Share Posted February 25, 2013 U should sell all that stuff and start over. What do u got thats so special? I would drown u lol ...im sure you cant. dont do that sort of thing "my dick is bigger than yours". it makes you look bad. Ya right Subs- 2 kicker cvxs 15 Amp- 1500 watt hifonics Wires-0g Deck-stock Link to comment Share on other sites More sharing options...
Swordlordboy1234 Posted February 25, 2013 Report Share Posted February 25, 2013 Oh look, we got a bad ass over here. My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect? Link to comment Share on other sites More sharing options...
Guest Posted February 25, 2013 Report Share Posted February 25, 2013 A corolla lol it already rattles to much. I just blew a alpine type r the other day i dont see you fitting 2 15's PROPERLY in that trunk. unless they made the trunks bigger. my 3 cube box barely fit through the trunk hole of the 94 i had. unless you use a sawzall and cut metal and fire the port and subs forward and seal off the edges. Link to comment Share on other sites More sharing options...
john253a Posted February 25, 2013 Report Share Posted February 25, 2013 Thoes 15 do well for what they are Idd stick with the 2 you have And when cash is better get a nice 2k 1ohm stable amp But first Install the aftermarket H/U you have And install a second battery or at least a better up front, then add a second Do the Big 3 if you haven't already Check you voltage drop at full tilt and then from that add a alt if needed Don't east your money on a cap unless its a bat/cap and even then I still would buy one So upgrades in this order H/U as u have already Big 3 if haven't already Good batt up front + 2nd batt New box built to what u want to achive 1ohm stable 2k amp(something decent) Then and only then if still not happy add another sub of new/different subs Link to comment Share on other sites More sharing options...
villarob713 Posted February 25, 2013 Author Report Share Posted February 25, 2013 Oh look, we got a bad ass over here. [/quoteI was js douche Subs- 2 kicker cvxs 15 Amp- 1500 watt hifonics Wires-0g Deck-stock Link to comment Share on other sites More sharing options...
Guest Posted February 25, 2013 Report Share Posted February 25, 2013 a proper box for those 15's he has will not even fit in the trunk LOL. thats like 9 cubes right there. Link to comment Share on other sites More sharing options...
villarob713 Posted February 25, 2013 Author Report Share Posted February 25, 2013 Thoes 15 do well for what they are Idd stick with the 2 you have And when cash is better get a nice 2k 1ohm stable amp But first Install the aftermarket H/U you have And install a second battery or at least a better up front, then add a second Do the Big 3 if you haven't already Check you voltage drop at full tilt and then from that add a alt if needed Don't east your money on a cap unless its a bat/cap and even then I still would buy one So upgrades in this order H/U as u have already Big 3 if haven't already Good batt up front + 2nd batt New box built to what u want to achive 1ohm stable 2k amp(something decent) Then and only then if still not happy add another sub of new/different subs Thanks bud ima try that Subs- 2 kicker cvxs 15 Amp- 1500 watt hifonics Wires-0g Deck-stock Link to comment Share on other sites More sharing options...
