I had this same thing happen a month ago with some memphis pr15s all the shops are all sales final round here and I asked them about dd1 and oscopes and noone knows what I'm talking about
bro, those type of shops are the ones you wanna stay away from, dude know nothing about sound audio, most time do hack jobs on installs.
The shop I use to go to tune by ear with a hip hop radio staion
I never had problem and they were clip to the fullest stock hu to hilow convertor off one the speakers gains who nowswere I would pit the eq all the way up on the bass on a prefab
And after 3 years it still kept playing and I had what this forums considers cheap cheap cheap as in no good
Makes me wonder why these top quality brands can't take a bit of clipping
If your subs quit when you were messing with your headunit then that is part of the problem.
On the headunit the output voltage signal to the amps (through the RCA's) is usually controlled by the subwoofer level. The level can be adjusted from +6 to -24. You will likely want to have this set between 0 and +3, just off the top of my head. I'd be careful if it suddenly starts working though because of how "professional" the install seems to be..
You probably either have that set incorrectly or have enabled a low pass filter or low frequency cutoff on the subwoofer output, unless the subs really are dead..
Hammerdown... 1%
quite possibly dead unfortunately then
what has more volts than the hu?
Edited by STEvil
Hammerdown... 1%
more volts doesnt help things, you can fry the input side of the amp or cause it to oscillate.
Hammerdown... 1%
  • Who's Online   0 Members, 0 Anonymous, 1533 Guests (See full list)
