ok so im comming home today and playing some music and all of a sudden my amp cuts off...so im like wtf....i check my ground connection and its nice and tight...then i think mabey my amp is blown so i pull it out and check the internals...everything a ok....so then i thought to myself wtf!!! why didnt i check the fuse first...sure enough the fuse is blown so i replace it...then i go to turn it on and i hear the bass...then when i turn it up it cuts off...not the power or anything but the sound...im thinking its rcas but im not sure...its getting late so i will check the ones on the back of the H/U tomorrow....any help or imput would be grateful...
MMM BASS OATS..ITS WHAT I HAVE FOR BREAKFAST
2 AudioQue HDC3 18'' subs
Rockford Fosgate T1 6.5 mids
MMATS 2000.05
XS Power D1200
Knukonceptz 1/0
Pioneer Premier DEH-P490iB
" Shit I can roll a blunt better than those bitches in Havana!"- Uncle Elroy
so it was fine low volume but when you turned it up it popped again?
yep...when i turned it up it cut off and now i wont hear a sound no matter what volume...checked fuse again and it isnt blown
MMATS 2000.05
XS Power D1200
Knukonceptz 1/0
the remote module on your deck might be going out. it happened to a buddy of mine last night. run a remote wire to your amp(s) directly from the battery to see if you get power.
i have everything except signal...which is why im pretty sure its the RCAs...but not sure at the same time
MMATS 2000.05
XS Power D1200
Knukonceptz 1/0
the ground on your pre-outs (HU or amp) might have went out. re-ground the rca's on the HU.
fuckkkkk i forgot how to do that....isnt there a link on here or a topic about it?
MMATS 2000.05
XS Power D1200
Knukonceptz 1/0
