power acoustik bamf 5500 monoblock amplifier
Cannon Corbitt White
That year Tahoe has the option to do a secondary battery under the hood on the passenger side under the firewall/fender brace. I like to utilize that space before throwing a battery in the cabin, but that's just me.
AGM stand for Absorbed Glass Mat. It's the material they use in the construction of the battery. Rather than being a lead acid battery that vents to the outside environment, it's a sealed battery with strips absorbed in a conductive gel material, simply put.
Lol kranny. Lmao that's funny.. its worked like crazy in every in both my trunks honestly. No pealing or drooping solid for years..
But real deadener iiisss better you can tell just working with it. He's right about being more efficient and not needing as much to do the job.
Lmao its fucking.made for roofing lol.
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
Sorry for not noticing which year Tahoe you have. I was referring to the 99-06 style, sorry :(
You should still have a kit available for an underhood battery tray. putting a battery in the cargo area isn't too bad though either. Only if you're using an AGM though. Don't put a flooded lead acid battery in the cabin, they vent toxic gas and can cause corrosion to nearby electrical components. More importantly, the toxic vented gas is the important thing to stay away from
lol it worked for me too, but tests have proven that you need like 6 layers of pns to achieve the same effect as like 50 percent coverage of the good stuff. you basically spend the same amount of money haha
That would be sweet to put 2 batts under my hood. Jesus there would more room in the trunk I f'in wish..
Setup:
Xs D3400/ Xs XP3000
its fusing is good for like 1700w (180 amps). at 14.4v exact.
all the "5500" watt amps are the exact same, by the way.
Yo Kranny Crecendo 5500 are like a BAMF :lol2:
"in the abundance of water, the fool is thirsty" Bob Marley
  • Who's Online   0 Members, 0 Anonymous, 612 Guests (See full list)
