So you want to run about 2700w total.
That will consume 3857w at 70% efficiency.
So you need batteries that can supply that. What do you have already?
What year s-10?
First you choose the batteries, then you choose the alt needed to properly charge those batts.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
Mechman makes a large case Gm for the 2.2 that includes a bracket for fit. Check out the first couple pages of my build log for some good s10 2.2 alt conversation...including the belt you will need.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
i have one battery and oem alt. 2002.
Honestly i have no idea what kinda of battery i should get, i only want to run one if possible. Was think XS Power, being the best to chose from.
Its more important to upgrade your battery first.
Ditch the stock batt and fit what you can up front. You may only be able to fit like a D1200 in yours. 2002? You can look it up.
A d1200 is good for about 2000w when used as a primary batts. You can try and fit a larger batt like a D2400 but may only get 3000w when used as a primary batt.
It would be advisable to add a second small batt like an XP950 to supplement the power.
Now, with that you can certainly run with the stock alt. Doing an upgraded alt will reduce charge time and run more efficiently though.
Based on the aH of a D2400 and XP950 combined, youd have 122 total AH. So any alt 122A and up will do nicely.
Mechman makes a nice 200A alt for your car. I cant post pricing but if interested you can PM me about that and batts.
Ed Lester
ShowtimeSPL Host
My old Build Log
any way you could get me a link to that mechman?
Its a G series http://www.mechman.com/index.php/products/g-series.html
I can PM more info
Ed Lester
ShowtimeSPL Host
My old Build Log
D3400 should fit in the front with slight mod to the tray.
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
