Engine sound in speaker
Antonio Moore
he's refering to an old pioneer issue with pico fuses which you would ground the outter metal jacket of the rca to get rid of induced noise. most likely not the issue your having.
Check every ground connection
deck ground, amp ground, rca connections, speaker wires, where you are grounded etc etc. Even a bad amp can cause ground interference
You most certainly have a ground loop. I was experiencing the same issue even over my balanced Symbilink cables. I noticed and removed the factory ground strap between my engine block and chassis (which made a chassis-block-chassis loop due to my existing frame and block to battery grounds) now I am noise free!
So u re grounded HU?
You ground the RCA shields to the head unit case. I have never had to do this with any Pioneer and don't recommend you do, if the pico fuse for your RCA grounds isn't blown it will be after you do this. It may take care of the noise but that should be treated at the source since it is obviously making it into your signal path somehow.
I'm gonna hate
I'm going to try regrounding the amp maybe that will work
A ground isolator will:
-Quiet your signal a little
-Help or resolve the noise completely
Without a guarantee to do either because once again the underlying problem remains the same. They are dirt cheap, though.
I'm gonna hate
I like to think it's not, it is easy to pop that fuse in most Pio decks but it only happens when they are installed improperly and usually isn't a problem for most.
I'm gonna hate
  • Who's Online   0 Members, 0 Anonymous, 826 Guests (See full list)
