What COULD happen if I ran 2500 watts of true power on my stock electrical? Besides killing my stock battery could anything else really get damaged? Assuming my power and ground are large enough to carry the current without catching fire.
What amp or amps are u using?
can fry alt can blow amp can blow sub can have a really bad day
I think it would just ruin amp and battery not blow subs and amp but I would play it safe with more power
lol no. like will said, voltage drop makes amps clip earlier. so instead of being clip free at volume 50 at 14v, you'll start to clip at lets say volume 40 at 12v. and you're riding at volume 50 the whole time, you're just clipping the day away.
Ohhh food for thought thanks. What amp are u using btw
Thinking an aq 2200 on lows with a small 200 watt amp on mids\highs that I already have. Not sure on the lows amp though, something that advertises 2000 rms but births around 2200 to 2500
Vehicle: 2014 GMC Sierra 2500HD WT
Head Unit: Pioneer DEH-
Mids/Highs: Focal Integration ISC 165’s (front)
Subs/Amps: TBD
I just never knew what could happen besides my battery draining so low that it kills the car while I'm driving or something along those lines.
Subs/Amps: TBD
My friend has 2k of true on everything stock with no big 3. Burnt battery + blown fuses
MOB-MOBILE: 2005 Honda Accord 5-Speed System: (1) Sundown Audio SA-15 (1) MB Quart ONX1.1500D (1) Kenwood KDC-248U
Speakers:
-Rear Dash: (2) Clarion SRQ6932R 6x9's SOLD
New MOB-MOBILE:
2011 G37S Sedan
System:
TBD
Instagram (18+) : DabsWitaBudget415
I'm pretty sure it all depends on which part of the amp fails if a different section failed the woofer could be fine or dead
04 dodge dakota ext cab 4x4
excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator
Equipment likes voltage. Low voltage=Current. Current=Heat Heat=Burnt up equipment.
  • Who's Online   0 Members, 0 Anonymous, 1197 Guests (See full list)
