Featured Box Build! Thumpers Enclosure Build Log Pics
hey thumper, I have been using slot ports for a couple years now when I build and after seeing your beautiful work I wanted to try this kerf technique. I have watched my uncle do it arched doorways but I haven't been able to get ahold of him to ask about doing it. So was wondering if you could answer a couple questions I have. So first, is there a certain number of cuts you use for certain angles? Also is there a specific distance between cuts like 1/4 or 1/8? And is a given depth on the cuts like 1/8 inch not cut or 3/4 through the board? Any ways if you could get back to me that would be gratefully appretiated.
Best of Luck and Cheers!
There is a point of diminishing returns on the amount of equipment installed, kinda like throwing money out a window.
looks good thumpper just curious do you ever go to any of the BC shows?
R.I.P!
(Nov-29-2009)
92 explorer
current build
That is absolutely amazing!!!!!!!! NOt like it will change the wow factor at all but what set was this done with??
this was done with the four *** 10" Icons in the last build
I'll make a better vid in the day light
will be hitting a few BC shows this year
Damn man a 145 at 24hz!!!! That's some serious lows outa those 10's in what looks to be a trunk.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
