Clarion EQ not working
So I finished hooking up my clarion today and it will not work. It turns on and it lights up but I have the main in RCA's running from the hu and the subwoofer amp RCA's plugged into the amp. When I take the RCA's out of the back of the eq and touch them together the subs play. So the volume and sub level are turned up on the eq. It turns on but there just seems to be no signal being sent. The settings are all to where it should be playing. I don't know what else could be wrong... Anyone?
03 Ford f150
2 Sa8 v2s
Ap 1800d...
Stinger 0 Guage
CA Auto/ Electric Big 3
Xs power d680 in parallel with new group 65 stocker
Soon to come another d680
Rockford Punch 6x8 3 ways in the front, Rockford Punch Pro 6.5s in the back
Soon to come Pioneers all around
Focal Solid 4 Speaker Amp
Kenwood KDC-X896
Memphis Line Driver
My build log: http://www.stevemeadedesigns.com/board/topic/160368-03-f150-king-ranch/
Youtube: https://www.youtube.com/user/LabAudio502?feature=mhee
Press the Aux button in and out. Anything from that?
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
i had a problem like this once, for my main 12v going into the EQ but i tapped into one of my switch wires, i was wondering for 3 days why my EQ would turn on and not process the signal, i accidentally turned my switch on and bam it was working, so i found an actual 12v that wasnt wired to one of my switches lol
was my own fault though, was bein dumb (thats why i use different color wires on switches now lol)
so all-in-all, my EQ was being powered because i had a 12v going into the TURN ON lead on the eq which was enough to actually turn the EQ lights on, just not enough to process the signal
or press aux
Team Sundown Audio
**CURRENT** -- 2012 Scion tC Build Click Here
**OLD** -- 2002 Pontiac Grand AM Build Click Here
check them out, slap me a comment
2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.
Head Unit - Alpine CDA-9887
Subs - 2x Z 12 v.2s - v.3 + NS Soft parts
Amplifier - Sundown Audio SAZ-3500D
Enclosure - 3.33 Cubes tuned to 34.66hz
Front Stage - JBL P660c 6.5" Components
Rear Deck - Powerbass 4xl 6.5" Mid-Range
Front Stage Amplifier - Sundown Audio SAX-100.4D
Wires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAs
Electrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700
Videos - http://www.youtube.com/user/BeAILsTaR13
Pressed aux on off earlier and nothing. The pos and negative are running straight to my battery in the back and my remote wire is tapped straight into my remote from my hu to my amp. All the wires are diff and are connected correctly.The amp turns On and works when I touch the RCA's together. so it's just something not puttin the signal through the eq...
03 Ford f150
2 Sa8 v2s
Ap 1800d...
Stinger 0 Guage
Kenwood KDC-X896
Memphis Line Driver
Anyone else have any ideas?
03 Ford f150
2 Sa8 v2s
Ap 1800d...
Stinger 0 Guage
Kenwood KDC-X896
Memphis Line Driver
I literally cannot find the problem anywhere. I have checked everything. The signal is there and worked for sure. But this thing just will not pass the signal through it. Once I get my speaker amp fully installed I will check the signal to that from the eq but I don't think it is going to do anything. My last guess is that this thing is defective.
03 Ford f150
2 Sa8 v2s
Ap 1800d...
Stinger 0 Guage
Kenwood KDC-X896
Memphis Line Driver
i had a similar problem, mines turned on but no signal. i ended buying another one and come to find out it was a ground. i traced the ground i had, and somewhere behind the unit were i tapped off for ground it had came loose. just check ur wires and stuff man. also i knew this cuz when i tried playing it, the blue lights on the clarion dimmed.
REFF'S
My link
EBAY
http://feedback.ebay...ck&myworld=true
I love car audio so much because I will never be done. I can never win, and I will never get it finished or perfect. It always has me coming back for more, I can never get my fill of it, but I get what I need.
I suspected that may be the problem. My ground wire is the same length as my power wire and it is run from my xs power batter in the back. I just used about a 10ft run of lamp wire from my back battery to the clarion. Maybe if I ground it right next to where the clarion is it will work right.
03 Ford f150
2 Sa8 v2s
Ap 1800d...
Stinger 0 Guage
Kenwood KDC-X896
Memphis Line Driver
I'm an idiot I know that has to be the problem. When I get home I will ground it right to the body under my center console where the eq is mounted.
03 Ford f150
2 Sa8 v2s
Ap 1800d...
Stinger 0 Guage
Kenwood KDC-X896
Memphis Line Driver
This thing is a piece of shit. It's grounded right to the body like 2 ft from it. It comes on and everything but will not put a signal through it. It has to be broken. I guess I will just call sonic and see what they can do. I have had it for about 2 months and just got to hooking it up. Will they send me a new one?
03 Ford f150
2 Sa8 v2s
Ap 1800d...
Stinger 0 Guage
Kenwood KDC-X896
Memphis Line Driver
  • Who's Online   0 Members, 0 Anonymous, 2236 Guests (See full list)
