ToNasty's Silverado (Linear Power stuffs)
So forgive my ignorance, but what is the point of using early '90s amps? Are they better or just a nostalgic thing?
One word ... Dynamics !!!
So the 90s models are better than the current amps made by linear power?
No Sir. From the numbers I've seen with the new LP amplifiers in different vehicles ... They are a freak of nature in power, dynamics, and clarity.
... but this is a topic for another thread. No need to spam up homies thread at this time.
It's quite alright. I don't mind. I'm learning a but myself with these amps.
Now you see what I'm talking on that 8002 on the speaker outputs ???
If I remember correctly, it should be off. With the taps set to 4 ohm. Since it's a mono amplifier, there's no need to invert the right channel. Feed back will work either way as long as it's wired correctly. If you compete for a burp number ... set you taps to 2 ohm and almost double power for sudden burst. Make sure you sub(s) wired to 4 ohm for this.
Just make sure to put it back for normal play.
Oh and just so you know ... I've seen an 8002 power Four 15s at one time.
Your correct. My bad it is 4 and 8.
My bad
Been a while since I worked with one.
On paper, it's 800 x1.
But then again, that's on paper. LOL
