System help!!
Ok so I just replaced my soundstorm DVD player with a kenwood kvt-516 DVD player and my subs are not hitting near as hard as they were with my soundstorm.if I have it at low volume it sounds alright,but when I turn it up to bump it,it sounds like its not picking up the deep bass and it kinda sounds like there bottom out like their under powered and I didn't have this problem with my old head unit.my pre amp output voltage is 2 volts....could this be the problem?..i dont know what the pre amp out put voltage was on my old one either....I have a ground loop problem which I'm working on but I don't think that would have anything to do with my subs not hitting like they should be...any body have an answer for me?!?
System:
Kenwood kvt-516
600 watt kicker amp
2 15" audiobahn aluminums
Sounds like the old DVD player had a better processor for your sub pre outs. Maybe a sub line driver?
I was told that and I started doing research and I read alot of good things and then I read alot of bad things....so I didn't know if I should get one or not.
Your sounstorm could've had 2v preouts, and your new headunit might have 4v+ preouts and it would cause your amp to clip.
*Rebuid in progress*
I don't know what it was on my old one...I tried searching it and couldn't find it all I found was that it was 85x4....but the pre out voltage on my kenwood is 2 volts.
Turn up the sub out
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I have the gain all the way up....bass boost barely even moved but I pretty put everything back to where it was with my old head unit cuz I adjust something's from my head unit.
