Jl J21000.1
cjohnson547
What are your thoughts on this amp. does it do rated power? here are the specs.
general specifications:
Recommended Fuse Value: 100A
Recommended Fuse Type: ANL at battery, 3x 35A ATC
fuses on amplifier chassis.
input section:
Low-Level Input: Single-ended with RCA jacks
Low-Level Input Range: 200mV - 6.5V RMS
High-Level Input: Single-ended with molded connector
High-Level Input Range: 630mV - 20.5V RMS
amplifier section:
Amplifier Topology: Class D Monaural
Power Supply: PWM switching type, unregulated
Rated Power with less than 1% THD (14.4V supply):
400W RMS x 1 @ 4Ω
500W RMS x 1 @ 3Ω
700W RMS x 1 @ 2Ω
900W RMS x 1 @ 1.5Ω
1000W RMS x 1 @ 1Ω
Frequency Response: 10 - 160 Hz (+/– 0.5dB)
Crossover section:
Low-Pass Filter: 12 dB/octave with continuously variable
cutoff frequency selection from 40 - 300 Hz. Non-defeatable.
Preamp outputs:
2-Channel, pass-through with unity gain, RCA-type jacks.
bass boost:
Single-band with 45 Hz center frequency, adjustable from
0 to +12dB.
remote level Control:
Via included, wired remote control knob. Full mute to
0 dB range.
It will probably do either rated or pretty close to rated.
I wouldn't expect it to be something hugely underrated though, like some of the amps out there
Not sure. I have no idea what those amps run for. It seems fair enough of a price, but I have no idea if it's a "deal" or not.
Are u talkin bout the jl v2 1000.1?
Sry i thought u might have misspelled. . All i can say is that i have the v2 1000/1 and its a tank. Only thing i dont like about my amp is that its not 1 ohm stable. But jl is a good brand and if your gettin a good deal id take it. You pay for the name but they still a damn good brand. Thats my .02 scents lol
  • Who's Online   0 Members, 0 Anonymous, 1095 Guests (See full list)
