MrSkippyJ Posted March 10, 2013 Report Posted March 10, 2013 I think you should ask the rep then about how much power it puts out. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
fox_racin4 Posted March 10, 2013 Report Posted March 10, 2013 the 18v amp is fine at 12v just protects at a high voltage then te 12v clamp the amp and see how much power its making... 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
Piggi3 Posted March 10, 2013 Author Report Posted March 10, 2013 He said its the same power but I wanna see if anyone can confirm this
sayhuh? Posted March 10, 2013 Report Posted March 10, 2013 Well, if it makes 14.5 at 18v and the 12v states 12.5, then isn't it safe to assume on the 18v configuration, that it would make 12.5 at 12v? No one can honestly confirm this, because I doubt anyone said 'Hey, let's test the 18v amp at 12v.' ....then again, anything is possible, just not plausible. Blown
AA98hoe Posted March 10, 2013 Report Posted March 10, 2013 From my understanding they have different rail voltages .. 18v makes max power at 18v 14,500 22v makes max power at say 15.8.. Say 12,500.. 12v version is going to be stronger on lower voltage .. Clamp the 18v one one 12v I bet it's under 10k at 1ohm TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
Piggi3 Posted March 10, 2013 Author Report Posted March 10, 2013 I'm running a 18volt on a 12 volt system but I have the chance to get a dc 9k for 300 on top of mine. Mind u the 9k is brand new so would I better with that amp. Or should I go with the 10k. Just trying to figure out my best option
armykyle1 Posted March 10, 2013 Report Posted March 10, 2013 The amazing fail in this post. It's like saying you can't run an NS-1 @12v lol. TEAM XS POWERTEAM HEAVY HERTZMy build- http://www.stevemeadedesigns.com/board/topic/194454-e46-bmw-build-pos/#entry2914134youtube- http://www.youtube.com/user/armykyle1big build starting
Piggi3 Posted March 10, 2013 Author Report Posted March 10, 2013 I no you can but would I get more power out of a 12volt amp or would it be the same
