enclosure opinions
port opinion?
If you have any questions relating to nutrition, lifting, or health in general, feel free to give me a PM and I will give you straight forward advice with no BS involved.
What are the height, width, and depth?
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
the box itself is L-44 w-26 h-26
Okay so the port you have would be a "0" common wall port. That is unless you have it in one of the corners of the box.
if the port is an L (3common walls) you need to have the same width as the port opening after the bend....like this
if the port is in the center (2common walls) and longer than the box is deep you would split the port in 2 and it would be half the width going each way after the bends....like this
http://www.stevemead...cherokee-build/
2005 Jeep Grand Cherokee
Alpine CDE-hd148bt
Alpine PKG-RSE2
PRV Audio (4) 6MB200 front/rear doors
PRV Audio (4) TW350Ti dash/rear doors
Kicker KX350.4
Obsidian Audio (1) 18 D4 v2
revamp (2) Stereo Integrity HT 18d2
DC Audio 1.2k
5.25ft^3 tuned @34hz
revamp Infinite Baffle Cpillar
AudioTechnix 60mil deadener
KnuKonceptz & SkyHigh wire (complete setup)
if you haven't built a ported box before, odds are slot ported (L port) would be easier for you....I would go with something in this neighborhood
h26 x w44 x 26d
port and subs facing forward with double baffle and .75 thickness...you would need to brace it a bit inside...
port h24.5 x w6.5 x 28l
gives you 10.2cubes with tuning of 31hz and port area per foot of 15.62
that would be pretty nice to run 2 18s...you could have the subs/port facing up as long as you have room for the port to breath, but 26inches high in a backseat you might as well wall it and fire everything forward!
Alpine CDE-hd148bt
Alpine PKG-RSE2
Kicker KX350.4
DC Audio 1.2k
Unless I missed it, you never stated what brand/model of sub your trying to build this for? Or if you are planning on powering them at, below or above their rated rms? This will make a huge difference in your design. All the "general" box, port and tuning information already provided look to be inline with all my reasearch, but the specific sub/s and power you decide on will effect your general design making it necessary to be fine tuned to what "your" sub/s actually like.
h26 x w44 x 26d
that sounds pretty decent. At 26" high i could still see out my rear window which is why i'm not walling it.
the most like candidates are either Fi Btl's or some Sundown's.
Right now the plan is to run each sub on a t1500.
any more port opinions?
Also, i will be going with the new sundown 18's x series.
  • Who's Online   0 Members, 0 Anonymous, 732 Guests (See full list)
