Agreene Posted April 17, 2013 Author Report Posted April 17, 2013 Build is 99 percent done. got the eq in now... one last problem I have a ground loop in my car after I installed the eq... its so annoying cant figure a fix anyone know a fix.. I orderd a ground loop isolator gana see if that works.. because I am left with no other fix's anyone with suggestions?? here is the video...
Pasta Prime Posted April 17, 2013 Report Posted April 17, 2013 Those skars sound really good man. Post some pictures of how you mounted the eq. New build coming........ YouTube:http://www.youtube.c...6?feature=guide Old Build Log: http://www.stevemead...d-on-the-cheap/ Old Screen name: Redrebel66
Agreene Posted April 17, 2013 Author Report Posted April 17, 2013 Those skars sound really good man. Post some pictures of how you mounted the eq. coming right up.... its ghetto. but good.. ghetto fabulous ??? haha
Agreene Posted April 17, 2013 Author Report Posted April 17, 2013 eq install. ghetto/ easy install .. still amature here guys so I didn't wana mess around with glassing the thing in especially how its in a prime spot and visible ripped the whole car out to run the rcas differently... what I did get my self into here haha... so I took the dash out and made a block of wood to mount the eq on pretty simple... bolted it down to the dash with a little hot glue. good to go ( I painted the wood block matt black also ) ran the rcas up through' attached everything back up screwed in the eq hooked up wires... and good to go. easy and clean ???
Agreene Posted April 17, 2013 Author Report Posted April 17, 2013 having a ground loop problem after I installed eq.... all grounds are good rca's ran on other side then power wire... good KNU krystal rcas.. any suggestions ?
Pasta Prime Posted April 17, 2013 Report Posted April 17, 2013 Looks clean man. Simple and clean always works. New build coming........ YouTube:http://www.youtube.c...6?feature=guide Old Build Log: http://www.stevemead...d-on-the-cheap/ Old Screen name: Redrebel66
rockFord_Expedition Posted April 17, 2013 Report Posted April 17, 2013 . Where did you ground your eq? And I just learned a whole lot about different output types and how they work better with certain types of cables. Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire
Stephen Dunnington Posted April 17, 2013 Report Posted April 17, 2013 Build is 99 percent done. got the eq in now... one last problem I have a ground loop in my car after I installed the eq... its so annoying cant figure a fix anyone know a fix.. I orderd a ground loop isolator gana see if that works.. because I am left with no other fix's anyone with suggestions?? here is the video... Is that Koan sound playing!?
Agreene Posted April 17, 2013 Author Report Posted April 17, 2013 Build is 99 percent done. got the eq in now... one last problem I have a ground loop in my car after I installed the eq... its so annoying cant figure a fix anyone know a fix.. I orderd a ground loop isolator gana see if that works.. because I am left with no other fix's anyone with suggestions?? here is the video... Is that Koan sound playing!?Yes
Agreene Posted April 17, 2013 Author Report Posted April 17, 2013 . Where did you ground your eq? And I just learned a whole lot about different output types and how they work better with certain types of cables. I grounded it on the same wire my hu is grounded to. That ground is coming out of the stock harness of wires.
