Mine leaked really bad with the last set up, a couple cans of expanding foam from the inside took care of that tho, if you do it be careful, too much and it'll come through the outside and look terrible!
Build log: Click
Feedback: http://www.stevemead...xbccp-feedback/
03 Chevy Blazer
- IPad Air 2
- ALPINE Head Unit
- 4 DC XL 18s
- 2 DC 3.5k
- ALPINE TYPE R 5.25 COMP
- 3 ALPINE TYPE R 6.5 COMPs
- DC 175.4
- DC HO Alt
- D3400
- 4 XP3000s
- KNU 0ga
- 60 SqFt Damp Pro
Lots more...
hum not bad idea with the xfoam idea and maybe ill try it, also the rear hatch window squeeks just generally driving and i found by putting a little bit of tape on the striker piece on hatch window helps but need a perm fix, blazers u gotta love there little squeeks and problems currently need too replace my pitman arm and im not looking forward too that at all, did the corvette servo on transmission last nite and can feel difference on 2nd gear shift and is really noticable when on hwy and in od and kick it down and let it shift back too 4th wide open throttle it shifts fast and firm.. just for 20buxs for the 2-4servo for corvettes with 4l60e trans
----------- no more blazer-------------
New ride 2000 s10 ext cab xtreme zq8 v4a
4.3 jba headers,pcm4less tuned,nv3500 5spd,8.5" diff,ported/polished heads
makes good daily driver not a racecar lol
system:
pioneer 7200hd deck,kenwood kfc708 with jl xd400.4
stinger 2gauge wire
mtx thunder 1501d
custom built box myself ported 3.13 slot port 40hz (2) 10" re audio sexv2d2- may do sxx upgrade soon after tune the sex first
kicker 4x6 cs dash.
i had a problem with my s10 blazer too. i never did figure it out, just got rid of it. but it had sooo many other problems. wasnt worth the trouble for me to fix it
today i went ahead and took everything apart and filled the rear side vents with greatstuff lol and removed the little flaps and then took back tailgate apart and added in sound dampening as best as i could reach they have two metal skins molded together so i put two layers on and and some on the panel itself on the inside corners and around hatch striker and door handle and it helped a good bit still some rattles now the rattle moved too the back passenger doors lol i could press in on the sides and stops so may just adjust doors tighter with striker adjustment.. big thanks for idea of expanding foam on one issue thanks sphinxbccp
system:
stinger 2gauge wire
mtx thunder 1501d
kicker 4x6 cs dash.
No problem! For your doors, it might be the actual door panels. The Christmas tree clips wear out and rattle, you can get more for pretty cheap. Also if you buy some foam tape (one sides adhesive, in stores by the insulation) and put that where the panels touch the door, it stops panel to metal contact and puts pressure on the clips to help stop those rattles also.
Build log: Click
03 Chevy Blazer
- IPad Air 2
- ALPINE Head Unit
- 4 DC XL 18s
- 2 DC 3.5k
- DC 175.4
- DC HO Alt
- D3400
- 4 XP3000s
- KNU 0ga
- 60 SqFt Damp Pro
Lots more...
I myself wouldnt mind just completly and permanatly sealing the back window.
I can still open the hatch. Anyone done that?
Meade sealed the glass on the Tahoe. I think he used the same stuff that keeps your windshield on.
Good stuff Sphinx!
Haha let's just say I've removed mine once or twice... ;)
Build log: Click
03 Chevy Blazer
- IPad Air 2
- ALPINE Head Unit
- 4 DC XL 18s
- 2 DC 3.5k
- DC 175.4
- DC HO Alt
- D3400
- 4 XP3000s
- KNU 0ga
- 60 SqFt Damp Pro
Lots more...
