Ascendant Audio Mayhem 15 Box Build
Just some pictures of a box assembly I just finished building this morning for a guy.
He has a dual 1ohm Ascendant Audio Mayhem 15, He will be running an AudioQue 3500.1 at .5ohms to the single woofer.
Pretty much started off plotting the box design out on Term-Pro Enclosure software (left screen shows the box response, it changed a tad more with more tweaking to the box). Also had a couple other designs I was messing with for other boxes :D
Cut my wood to ruff sizes
Basic assembly started
Cut some port spacers
Dry fitting port
Port assembly (where the sexy happens)
nice wood working skills brian.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
A little bit of clean up sanding to remove excess glue
Port gluing
Port glued and nailed, with a little bit of weight to help hold it down tight since I have no clamps to reach that far into the box
First baffle already on, getting the 2nd baffle ready
I use a lot of glue, my choice is Titebond 3. Always spread a good even coat, just pouring it on and assuming the pressure from the wood will spread it even is a no no.
More weight while I let the glue cure a little bit
Third partial baffle, just to give the woofer mounting screws a tad more to grab into
Rounded over the outside edges with a 1/4inch round over bit
Then hit both sides with a 1/4inch round over bit
Glued and nailed in place
A smaller brace for the port wall
As if you havent been able to tell, I love lots of glue!
Glued and nailed into place
So here are some interior gut shots before I close it up, the 3rd partial baffle is just resting in place. It wont get glued and nailed until the top is on and the other 2 baffles are routered out so I can get it flush with the other holes.
Top marked out and ready for glue and nailing
Many passes with the router and the front 2 baffles are cut out
  • Who's Online   0 Members, 0 Anonymous, 1467 Guests (See full list)
