What I was thinking is 4 tweets total on channel 1-2. Two tweets per side.. 4 ohm wired down to 2 ohm to get a good amount of power to them.. So 2 tweets per side and use the crossovers in the amp to filter out the unwanted freq.
Then use the 3-4 channel to power 4 mids and as the same as above an use the crossovers and wire down to 2 ohm to get a good amount of power to them and be able to control the gain levels separate on the tweets and the mids ...
Does this sound like a good plan or am I missing something?
The amp is the 100.4d so it can be used as two separate amps and has the crossover control I think I need
I'd luv to get the sa6.5's but at 200 a set I'm not sure I can swing that much... Do I have any other options?
250 amp mechman alt
Sundown 100.4D
Sundown 1500v2 now goin to the cruze
Sundown ZV3 12d2
Sundown sa6.5cs X2
Kenwood X597
Trying something new
2011 Chevy Cruze
X8
1500v2
That's exactly how I run mine basically just less speakers. Sounds good man get wiring!
04 dodge dakota ext cab 4x4
excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator
Ok so I have made room in the budget for 2 sets of the SD sa 6.5 component sets .
So now my question is how much power do they like and would it be better to use the 100.4 crossovers or use the supplied crossovers that come with the components and just run them off each channel @100rms to each side?
I was thinking since a lot of the dubstep music I've listen to goes from left to right and back to front and if I wired down to 2 ohms ( tweets off channel 1+2, and off the front preout set and the mids off channels 3+4, and off the rear preout sets) I would loose some of the stereo effect over running them off each channel separately ..
Would the extra power be worth it of having each channel separate for the stereo imaging be better??
250 amp mechman alt
Sundown 100.4D
Sundown ZV3 12d2
Sundown sa6.5cs X2
Kenwood X597
2011 Chevy Cruze
X8
1500v2
You can do that, just back the gain off on the tweeters channels so you don't over power them.
Edit: for your second question, you would lose that effect but it would all come down to personal preference. Try it, if you don't like it just go back.
Edited by RooTxBeeR
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
Do what??
250 amp mechman alt
Sundown 100.4D
Sundown ZV3 12d2
Sundown sa6.5cs X2
Kenwood X597
2011 Chevy Cruze
X8
1500v2
Do what??
Run the tweets off the first two channels. Just back the gain off with the tweets to power them properly.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
You don't think I'm loose any sound quality by not having separate front to back separation ?
250 amp mechman alt
Sundown 100.4D
Sundown ZV3 12d2
Sundown sa6.5cs X2
Kenwood X597
2011 Chevy Cruze
X8
1500v2
Read my edit. I said you would lose that stereo effect. But with a good Front stage you may not need rear fill.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
Yea I'm pretty sure ill want that stereo effect now the more I think about it ...having that music sound like it coming from different ways is what makes listening to that type of music so kewl I think...an I'm really going for sound quality this time around... Just hope 100rms is enough to make them sound great
250 amp mechman alt
Sundown 100.4D
Sundown ZV3 12d2
Sundown sa6.5cs X2
Kenwood X597
2011 Chevy Cruze
X8
1500v2
  • Who's Online   0 Members, 0 Anonymous, 1579 Guests (See full list)
