Adding a second ground from pioneer HU to amp ground?
My skar subs are making a squeaky/ whinny sound when there is no music playing at all. I was told that i needed to ground my pioneer head unit in order to stop this. Any insight??
Vehicle: 2001 Chevy 1500
Radio: Pioneer
Coaxials: Rockford punch 6.5"s and 4x6's
Subs:Skar VVX 10's (dual 2)
Sub Amp: DD M3A
Wire:Raptor 4 Gauge
Electrical:150 amp alt, big 3, reg. batt.
sounds like the pico use. wrap a wire arund the rc preouts on th hu and then ground the wire to the hu chasis.
you can google pioneer pico fuse fix for pics and vids.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
so wrap it around the rear outputs or the front? or both?
Radio: Pioneer
Sub Amp: DD M3A
Wire:Raptor 4 Gauge
wrap it around all the rca outputs (be sure the wire make contat with the rca strip the plastic off)
find screw on the hu that you can loosen up and the wrap the wire around that
tighten the screw down and your done.
google search it for a vid, there are plenty out there.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
whenever i have my radio on, i pulled my rca's out the sub amp and its still doing it.
Radio: Pioneer
Sub Amp: DD M3A
Wire:Raptor 4 Gauge
well first, you should never pull the rca's out while its powered on. that is one of the bigest reason the pico fuse inside the hu goes bad. if i was you i would still try it and if not check all the grounds for you amps, batteries, and alt.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
okay i will. never knew that would blow a fuse in the HU. ill try that later tonight. ground it to the deck itself or to the chassis of my truck?
Radio: Pioneer
Sub Amp: DD M3A
Wire:Raptor 4 Gauge
Yeah I never knew that about RCA's either. I used to pull mine out with my old HU all the time when I was checking stuff, I never came across a problem. Maybe I was lucky.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
to the deck itself
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • Who's Online   0 Members, 0 Anonymous, 1322 Guests (See full list)
