4 channel amp
flexinfusion
i got a set of rockford fosgate t1675-s components in the front doors and a set of t165 2 ways in the rear doors. what amp would u guys recommend to power these
2009 fusion
Steeda Mods kenwood DDX418
RF T1675-s Front doors
RF T165 Rear doors
OLD SETUP:
ab XFL 1222Audiopipe 1500d
2.5cu ft 32hz
i got a ddx418 Headunit
2009 fusion
RF T165 Rear doors
OLD SETUP:
2.5cu ft 32hz
wouldnt that be too much power. the speakers are only 100 rms 200w front and 70rms 140w rear. 4 ohm
2009 fusion
RF T165 Rear doors
OLD SETUP:
2.5cu ft 32hz
would putting some polyfill in my doors help with the sound from the mids
2009 fusion
RF T165 Rear doors
OLD SETUP:
2.5cu ft 32hz
Have you thought about running a 4 ch & a 2 ch amp? Bi-amp the components w/ the 4 channel and run a 2 channel to the rear. Depends on your budget also. I know the components sound and run a bit better bi-amped and even better active. I run 2 T400-4 to 2 sets of T265 comps active and they scream on 75 RMS. My doors are deadened big time though, 80mil Coolmat & 1/8" dynomat acoustic foam and they sound amazing Off the DEH-80-PRS.
im on a tight budget for this build i spent all the money i let myself on these speakers and the steeda stuff.
and what does running them active mean? im sorry i dont know a lot about most the car audio stuff i know just a little bit about subs.
and what does bi-amp mean? running them off 2 amps?
2009 fusion
RF T165 Rear doors
OLD SETUP:
2.5cu ft 32hz
Well if your on a budget then the rest doesnt matter because it makes for a more complicated set up. Whats your budget for a 4 channel amp? T400-4 run about $230 but you might be able to get P400-4 for about $170 if you wanted to stick with RF. But there are many other types of amps out there, find your price point and search from there.
find a couple options in your price range and then maybe run them by people here to see what people think...I have seen tons of people running MBquart Onyx 4channels on here because they are affordable and put out decent power...
http://www.stevemead...cherokee-build/
2005 Jeep Grand Cherokee
Alpine CDE-hd148bt
Alpine PKG-RSE2
PRV Audio (4) 6MB200 front/rear doors
PRV Audio (4) TW350Ti dash/rear doors
Kicker KX350.4
Obsidian Audio (1) 18 D4 v2
revamp (2) Stereo Integrity HT 18d2
DC Audio 1.2k
5.25ft^3 tuned @34hz
revamp Infinite Baffle Cpillar
AudioTechnix 60mil deadener
KnuKonceptz & SkyHigh wire (complete setup)
i want to stay under $150. and id perfer a RF amp To to stick with all rockford. down the road i want to get a small RF 10 and build a fiberglass box in the pocket of my trunk
2009 fusion
RF T165 Rear doors
OLD SETUP:
2.5cu ft 32hz
  • Who's Online   0 Members, 0 Anonymous, 867 Guests (See full list)
