the1uwannab Posted March 21, 2013 Report Posted March 21, 2013 I dont think anyone answered your question yet but you have 6.5" front and back with 4" of depth both in the front and back the rk6 is 2.75" deep so should fit no problem.
BassMunky Posted March 21, 2013 Author Report Posted March 21, 2013 2 12" subs of the right subs could SLAM in that airspace though and sound better than 2 15" subs in a cramped environment Welll i wanna do hairtricks no wall though. Which sound louder than? 2 12 2 15 1 18 Also I wanna play the low lows.... in the 20-30hz range kine. Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
BassMunky Posted March 21, 2013 Author Report Posted March 21, 2013 I dont think anyone answered your question yet but you have 6.5" front and back with 4" of depth both in the front and back the rk6 is 2.75" deep so should fit no problem. Where did you get this info from? Sory tried searching everywhere and came up short in finding the answers. Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
the1uwannab Posted March 21, 2013 Report Posted March 21, 2013 If you go to metraonline.com and put in your car it gives you speaker sizes and depth
BassMunky Posted March 22, 2013 Author Report Posted March 22, 2013 thanks man that a good site for info also that pretty deep for speaker almost can fit 8 in there Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
the1uwannab Posted March 23, 2013 Report Posted March 23, 2013 Yeah i use it all the time has almost every car
BassMunky Posted March 24, 2013 Author Report Posted March 24, 2013 What you see there is the box basically touching the back of the seats. It's got a little more height and could still stay below the headrests. I didn't get anymore pics than those two, they were taken just to see what I could fit comfortably. It's got a couple more inches on width as well. Im not taking into consideration the angle of the seats. I've seen 15" subs fit too but you need a much bigger box, plus I can't imagine being able to fire the port back. Would be ideal for this car to have subs up port up just because of space issues. Wouldnt it sound better with sub up and port back?like sub up port back with the port in the middle or something different? Anyone else got builds in the second gen scion xb thanks looking for more ideals. Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
BassMunky Posted March 26, 2013 Author Report Posted March 26, 2013 bump...... Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
skittlesRgood Posted March 28, 2013 Report Posted March 28, 2013 two 15"s crammed in the cargo area with a rear firing port? probably not going to work too well for you. you'll need at least 4" between the port and the rear hatch. If I answered you in a well mannered, informative way, you asked a good question or had a good attitude. If I was an asshole, you asked a stupid question or you had a fucktard attitude... or I was in a bad mood. Team BassickHU: Pioneer AVIC Z110Front: Peerless SLS 6.5", Peerless HDS 4", Rainbow tweeter - running activeAmp: JL HD600/4 and DC 4 channel (bridged to midbass)Processor: JBL MS-8Subs: 2x 12" AA MayhemsAmp: DC 3kElectrical: DC power 270xp alt. 1/0 big 4. XSpower D3400 and six D680s. http://www.stevemeadedesigns.com/board/topic/121795-29-update-the-buick-is-getting-a-rebuild/ Top career scores: DBdrag 151.7 MECA SQ 82.25My SOTM build Yeah. im pretty sure they dont warranty retarded people.
CleanSierra Posted March 28, 2013 Report Posted March 28, 2013 two 15"s crammed in the cargo area with a rear firing port? probably not going to work too well for you. you'll need at least 4" between the port and the rear hatch.I have the same car too Skittles but he's convinced since he's "seenit done" or "heard about it being done" he wants to stuff the hell out of the cargo area. BassMunky, you will need to get every.possible inch out of the cargo area and if you want to leave proper clearance between the box and the rear hatch, you will need to probably go above headrests. The widest I've measured 38 inches. Height below headrests is19.5" and top depth is 15-16"bottom depth is 26". All of those dimensions are MAX. It leaves no room for a gap between port and hatch. Im not the one you want to try to troll. Just a fyi for you.
