dc audio xl 12 enclose tuning question. f3?
throttle98
Hello. I am new to this forum. I've been reading for a couple hours, searching google ect and am still confused. I just bought me 2 dc audio xl 12's today and am now trying to get some sort of idea for a box. I want a box tuned to 32hz (I think). I love the lows, especially c and s. and lots of bigpimpin's stuff. So now I'm reading about f3 and am just confused as hell. Is this a bad woofer for lows? is f3 and fs the same? People are saying they tune to 32 but play songs that are 26 hz?? doesnt that hurt the woofer? does it hurt if I play it at low volume notes under the tune? Right now I'm running 2 earthquake subzeros and there louddd. running around 2200 rms. This new system will be double that. I'm excited. ha . Anyways heres the specs:( the 12" is the second spec of each category.)
Mounting Depth
6.5"
7"
8.25"
9.25"
Mounting Hole Diameter
9.25"
11"
14"
16.75"
Outside Driver Diameter
11.0"
12.5"
15.7"
18.5"
Motor Width
8.75"
8.75"
8.75"
8.75"
Weight
53lbs
54lbs
56lbs
57lbs
VC Diameter
3"
3"
3"
3"
Displacement
.18³ ft
.19³ ft
.23³ ft
.26³ ft
Magnet Weight
50lbs
50lbs
50lbs
50lbs
Power Handling RMS/Peak
2200/4400
2200/4400
2200/4400
2200/4400
Impedance (Ohm)
D.7/D1/ D1.4/D2
D.7/D1/ D1.4/D2
D.7/D1/ D1.4/D2
D.7/D1/ D1.4/D2
Sd
314.00 cm²
494.00 cm²
791.00 cm²
1159.00 cm²
Vas
12.42 liters
25.77 liters
66.02 liters
144.36 liters
Cms
0.085 mm/N
0.08 mm/N
0.07 mm/N
0.07 mm/N
Mms
171.77 g
213.7g
306.7 g
346.7 g
Fs
41.7
38.5
34.3
32.3
BL
BL 22.73 N/A
22.73 N/A
22.73 N/A
22.73 N/A
Re
3.98 Ohm
3.98 Ohm
3.98 Ohm
3.98 Ohm
Le
5.2mH
5.2mH
5.2mH
5.2mH
Qms
11.24
12.92
16.55
17.6
Qes
0.35
0.403
0.516
0.548
Qts
0.34
0.391
0.5
0.532
Xmax
26 mm
26 mm
26 mm
26 mm
Ref SPL @ 1 watt
85.9 dB
87.5 dB
89.0 dB
91.3 dB
Suggested Sealed
N/A
N/A
N/A
N/A
Suggested Ported
1³ ft
1.5³ ft
3.5³ ft
6³ ft
I'll be running 2 12's and love lows. Could anyone help with with the box. I'd be willing to toss some money around. Especially if theres anyone in nj or ny or pa area who can build the correct box for me. Thanks a lot guys.
Ok, post max dimensions you can fit for a box, amp and vehicle models. BTW playing below tuning can bottom out a sub but there are way around for that not to happen.
F3 is the point where your enclosure's output drops off by 3db - pretty much the lowest it will effectively play. This normally occurs at a slightly lower frequency than Fs (I believe the word you were looking for is Fb actually)
Fb is the tuning point of your box
In my own experience, people tend to be tuned lower than they really are. My enclosure, on paper is tuned to 32hz and the box played well down to 27hz. But the measured tuning frequency turned out to be 33hz.
When I shrunk my box, on paper it was tuned to 40hz, but I measured the tuning frequency at 35hz. In a box tuned to 35hz, it's not unreasonable for it to play down to 30-31, which mine does.
So put this all together for someone who doesn't have an IM-SG or clamp meter to measure their tuning frequency. They think they are tuned to 40, but can play low 30s no problem. Or think they are tuned to 35 but are really tuned lower, that's why they(me) can play mid-high 20s
Hey. Third time writing this.. I looked up the meter and found the owners manual. Its interesting finding what hz your car rattles at and to dampen it. Anyways. Does this tuning have to be done before or after the box is built? anybody in the nj pa ny ct area with this meter? I want to have it tuned correctly. I dont want to play 32 hz songs with the box thats tuned higher and hurt my babies. ha.
my vehicle is a 2001 ford taurus sedan, which back seats fold down. I have 2 brutus 2400's which i'll be running at 1 ohm (2400 rms). The dimensions of my box now are (W x H x D): 33" x 16-1/2" x 21".
So here is a suggestion 2 DCXL12s on 2 BRZ2400, make sure that you read the notes below the pic:
Enclosure Specifications:
Fb = 32 Hz
Vb = 3.2 ft^3
External Height = 16.5 in
External Width = 33 in
External Depth = 20.75 in
Port Width = 3 3/4 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Front & Back (3 parts) = 33 x 16 1/2
Left & Right Sides = 18 1/2 x 15
Top & Bottom = 33 x 18 1/2
L Port Internal Assembly Parts:
Front to Back = 14 3/4 x 15
Extension = 16 7/8 x 15
Assembly guide (generic dimensions):
Important notes:
- The 45s if you want to do them are 2 1/2" wide except the one/ones inside the port, if you want that let me know.
- All trunk boxes built outside the car need to fit in their way in not just have the right dimensions.
- The port needs 3 3/4" of free airspace in front of it for proper operation.
- Setting your amp subsonic filter to 28Hz is suggested.
Thanks for the design. Still confused on when I have to do the im-sg tuning. Also anywhere or anyone have the tools in the nj ny pa area? I want this to be bad ass ha. I dont want to harm these babies. Also if the fs is 38.5, if I put them into a 32hz tuned box would it sound worse than a 38 hz box? I am looking to play lots of c and s and decaf stuff
You don't need to use the im-sg or other tools unless you want to determine your real tuning if that is important to you (which may be the case for competitors), but be aware that it will change with temperature somewhat. And there's no problem tuning a few Hz lower than Fs, if your are playing decaf and the likes tuning low can help the subs from possible mechanical failure, also setting your subsonic filter can help as well.
  • 3 years later...
I know this is an old thread but I just wanted to say I built this box with the design above for my 2 DC XLs and all I can say is wow! It really lets these subs beat. I had them in a generic QBox that was suppose to be tuned to 34hz. Thanks for the design Joe X!
2001 Buick Lasabre Limited
DC Power engineering 270 Alternator
JVC Arsenal KD-R975BTS
4-XS Power D3400
Mclaren Audio MLM-580 5.25 mids (Front Stage)
Rockford Fosgate Power T1T-S Tweets (Front Stage)
Memphis Car Audio MCX69 (Rear Stage)
Crescendo BC5500
2 DC Audio 12" XLs
3.2 cuft box ported, tuned to 32hz
  • Who's Online   0 Members, 0 Anonymous, 1237 Guests (See full list)
