got ? about the sk2500.1
Robert Henthorn
I know skar said 3030+ rms at 16v
Not sure if that's true. I'd like to clamp mine. I do know that mine doesn't get hot at all after hours of full tilt in 70 degree weather, even though that's not your question.
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
cool and do you now how much power I can get out of a 2500 on 16 volt with a high charge
what is a high charge?
are you wanting to do a 14v system that CHARGES at 16v? or a 16v that CHARGES at 18v? there is a major major difference. high voltage isn't a thing to fuck around with since you can start fires if done improperly.
I no I am running a ex alt just for the 16 volt batt
Wait, so you have a 16v battery? Is this ran to the front battery? Or is the battery just connected straight to the amp???
a little more details ..clearer details.
EDit: I may be misreading. but you have 2 alts; one for 14v and the other for 16v?
10501650_10203332501847103_1859383749711
Blown
ok I am running 2 alts one to the front batt to run the jeep and one to the back on the 16 volt batt for the amp the one running to the 16 volt batt
has a exsternal regulator so I can charge at any voltage I want under 22 volts I will be running the amp off of the 16 volt batts
  • Who's Online   0 Members, 0 Anonymous, 1091 Guests (See full list)
